Washing car after machine polishing
Hi all
I've noticed some members wash their car after they have completed their machine polishing, prior to adding a coating/wax/sealant.
My concern is inflicting marks on a freshly corrected surface.
Should I be worried?
Re: Washing car after machine polishing
Stuff lands in all sorts of nooks and crannies. You got a better chance adding in some MM on polish removal than a post quick wash, IMO.
Originally Posted by cheekyage
Hi all
I'm glad I'm not one that washes
their cars after completing the last
polishing step.
If I were to use any "cleaning"
product after polishing...it would
be the Coatings' manufacturers'
recommended panel-wipe(s)...
before applying their Coatings.
•Then there's the below axiom,
of which I'm always mindful:
"The less the paint is touched..."
If a lot of dust from the compounding stage settles in the panel gaps and crevices I'll pressure wash and rinse the vehicle before moving on to final polishing.
why not get a good microfiber to wipe the dust down. Mist it with a clay lube or something.
Hi all
I normally wash after my cutting step before I start polishing. But since the car is clean except for dust, I'll usually foam, pressure wash and dry. After polishing I'll do an eraser/IPA wipe down before coating or sealing.
Don't be worried about touching the paint. You eventually have to and if you're concerned about instilling swirls while washing then there's no hope in maintenance. Why aren't you as concerned instilling swirls wiping off a coating or wax but only for washing? Be careful, use the right techniques and you'll be fine.
Counter productive. You'll leave something of the lube behind.
WOW another step I've been missin'
I will use compressed air to blow a lot of the compounding dust off. If I am using Optimum Gloss Coat I will use ONR followed by optimum paint prep due to product synergy. If I am using another coating I will use the Meguiar's D114 that I still have. I do the same if I am using a sealant as my LSP.
By alanG40 in forum Off-Topic
Last Post: 04-15-2015, 08:43 PM
By apollofin in forum How to make money detailing cars
Last Post: 01-13-2015, 06:10 PM
By arjo.reich in forum Auto Detailing 101
Last Post: 02-24-2013, 07:17 AM
By InTheBuff in forum Auto Detailing 101
Last Post: 06-13-2010, 11:09 PM
By darksparkz in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 04-27-2007, 11:55 PM
