Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Super Member MarkD51's Avatar
    Oct 2012
    Sheboygan Wisconsin
    3,130
    Re: Porter Cable 7424xp problems?
    Quote Originally Posted by AuroraDetailing View Post
    If I have to try correcting with a PC, I always put it on 6 and not a lot of pressure to allow it to keep rotating. If I'm just doing a final polish, I don't worry about it spinning. I use mostly hexalogic pads, so the edge isn't smooth and easy to see if is spinning so I've never bothered to mark them, and my backing plate has seen a lot of use so has enough markings on it to see if it's spinning. I have a Flex now that I use most of the time so I don't even bother trying to do any correcting with the PC, which actually sounds like is about to blow up now. It's about 3 years old, but hasn't been put to full time use so I would have expected it to last longer. But now it's making a lot of clacking noises inside, which is why I upgraded.
    The one major dislike with the PC7424XP, was they created a speed dial with no detent at speed 5.5. This may have been the "sweet spot" for this machine, not only so much for correction, but the PC really makes a hell of a lot of noise on speed 6! I ran it once like this, and seriously considered hearing protection.
    Maybe one day I'll graduate. Perhaps the Griots Boss, or the Flex free spinning DA? Some might say, why mess around, go for the Flex 3401 and be done with it!
  2. #22
    Aug 2012
    Laguna Hills
    430
    The best performance I got out of my PCXP was using the Meguiar's microfiber pads. The thin pads really help the machine out. They have since come to the market with thin foam pads. I haven't bought any of these, but they seem to aid in reducing the bogging down/stalling issue.
    Meguiars DA Microfiber Cutting Discs, compounding discs, cutting pads
    Meguiars DA Microfiber Finishing Discs, finishing pads, wax pads
    Lake Country ThinPro Foam Pad System 5.5 Inch
    "The shortest and surest way to live with honor in the world is to be in reality what we would appear to be." --- Socrates
  3. #23
    Aug 2012
    Laguna Hills
    430
    Also, here's a good, short write up from Mike: http://www.autogeekonline.net/forum/...-polisher.html
  4. #24
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,034
    Quote Originally Posted by MarkD51 View Post
    I wouldn't say using the handle does more harm than good, in the sense that it's not going to add any considerable weight to the machine, and be the cause of bogging.
    I use the PC both ways, with and without handle. I feel at times, the handle can give a little better control of the machine, usually on horizontal surfaces, offers a better hold, and can help at times with insuring you're running the pads flat to the panel surface. We PC owners all know how sensitive a machine like the PC can be with a Pad ever so slightly canted against the body panels.
    Some new to machine polishing tend to put a little extra preasure on the handle, at least that's been my experience.
  5. #25
    Super Member Jimmy Vegas's Avatar
    Mar 2016
    Pittsburgh, PA
    293
    Quote Originally Posted by AC in OC View Post
    I've also had great luck with the Meguiars MF pads using my PC. I picked up the 5 inch kit to do some work on my Chevelle. (There is also a 6 inch kit available.) I'll be posting pictures of the results in this thread.
    "All persons living or dead, are purely coincidental."
    - Kurt Vonnegut
  1. New PORTER-CABLE 7424XP from Amazon - Power switch problems?
    By MasterBlaster in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 12-19-2018, 07:25 AM
  2. Porter Cable 7424XP Pad that comes with it
    By carlg in forum Auto Detailing 101
    Last Post: 08-22-2018, 11:00 AM
  3. Porter Cable 7424XP
    By mcpp66 in forum Ask your detailing questions!
    Last Post: 01-10-2018, 03:51 PM
  4. Help with Porter Cable 7424XP
    By stephen82 in forum Auto Detailing 101
    Last Post: 05-28-2017, 02:19 PM
  5. Porter Cable 7424XP Help
    By grandprix2plus2 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 12-29-2011, 11:54 PM
