Also if you want to try to go less aggressive you could try Griots All in One sealant. I use it with LC Hydro tech tangerine pads and for a one step it does a good job.The photo is a 50/50 shot on a VW Jetta.
Sorry if I'm correcting you, minor snafu, you probably meant 5.5" Pads with a 5" Backing Plate.
Not really a snafu. The op asked me about what pad sized I used when I made my original statement and in saying this, the Meguiar's microfiber pads are listed as 5". Technically they are a tad larger than the 5" backing plate.
I recently purchased a 2011 CL550 and the paint was in great condition with the exception of years of carwash swirlmarks. That car has some pretty hard paint too. I tried McKee's 37 AIO and it didn't do anything to the paint (I don't like the performance of AIOs honestly) so I can't recommend that, especially on that car. It wouldn't even remove waterspots.
I then tried McKee's 37 compound and it worked wonders. Honestly it didn't need to be polished down with anything else, but I used the jewel wax on it anyways. It came out spotless...
so I say try McKee's 37 compound followed by jeweling wax, which is a very fine last step polish that has waxes in it saving you a step.
Thanks for all the help guys! My latest attempt was using a 5" CG microfiber pad with MG 205. I ordered MG 5" Microfiber pads and MG D300 with their foam cutting and polishing pads as well.
So, I'll probably use the D300 with foam pad on setting 5 first and go from there!
Ok so I did a 1x1 test spot and it the MG D300 with microfiber cutting pad and PC on 5 cleared up a good amount with 6 passes. It looks like I may need to bump it up to 6 but in that one spot I'm gonna do setting 5 again for another 6 passes.
Sounds like you are on the right track. Take a look at this write up on how to use D300 and microfiber. I am not sure how good those microfiber pads are that you are using.
