View Poll Results: flex vs long stroke machine
Voters
38. You may not vote on this poll
  • flex
    25 65.79%
  • long throw rupees or gg
    13 34.21%
Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 50
    Jul 2016
    3,328
    Re: FLEX XC3401 vs any of the new long stroke polishers???
    Quote Originally Posted by anonymoususer View Post
    I'm quite the opposite to some of the other experiences. The Flex 3401 is very smooth for an orbital (albeit forced rotation orbital) and it does not fatigue my hands. Compare it with a GG6, Porter Cable XP7424 or any one of the rinky dink machines, and you'll notice a tremendous different in vibration. That said, the Flex 3401 exposes bad technique and will fight you if the pad is not flat. But to confirm what the others have said, the Rupes Bigfoot is smoothest orbital. I owned the Rupes Bigfoot 15ES and i sold that in a couple months because it 1) was only slightly smoother (meaning not a big enough difference for me to consider it a significant advantage over the Flex), 2) stalled like crazy on concave panels, 3) the Flex 3401 can deal with small edges with little pad contact, 4) and not wanting to deal with switching machines my Rupes 15ES just didn't see any use. I've owned pretty much all the major polishers on the market and i recommend the Flex 3401. Currently in my personal arsenal are the Flex 3401 orbital, Flex PE14 rotary, Harbor Freight DA for carpet duty, and Rupes Nano Long Neck.
    what do you use for product when you do carpets? i just did mine by hand and they are taking a beating, i have a harbor freight i just dont know how to use it for carpets? got any tips?
    Super Member Harry Da Hamster's Avatar
    May 2013
    863
    Another reason i would recommend the Flex 3401 is because you plan to get one high end polisher. If you only have one polisher, the Rupes Bigfoot will not be able to handle ALL duties. The Flex 3401 is the perfect machine to handle all duties if you can only choose ONE.
  3. #13
    May 2013
    863
    Quote Originally Posted by fightnews View Post
    You can get a super cheap Harbor Freight DA for less than $60 shipped (if i remember correctly, with a coupon code), get a cheap orbital brush attachment, and go to town on your carpets.
  4. #14
    Super Member coles_paint_correction's Avatar
    Dec 2012
    Lancaster CA
    419
    I think if i knew what i know now, i probably would've got a flex 3401 instead of the rupes or griots.
    That being said because most cars have curves/edges and it's just time consuming sitting there trying to get the long throws to spin right
    flex 3401 would be a perfect choice for only one if you could only get one.
    All in all though it's best to have a variety of machines. My current setup is boss g21, flex 3401, griots 6 converted to a 3.5 setup.
  5. #15
    Super Member DaveT435's Avatar
    Jun 2012
    Arlington Texas
    3,982
    If you are currently using a traditional DA, especially if it's a PC you won't have any problem going to a long throw. You already know how to keep the pad spinning on curved panels. There will be a learning curve going with the 3401, and even then it will work you more. Don't get me wrong it's a great machine...it's a beast. Personally I'm going to end up selling mine because with my back problems it shortens the amount of time I can work without taking a 2-24 hour break. My philosophy is that if your doing this for pleasure or a hobby why would you want to make it harder and more tiring? The long throws are so much smoother and using Rupes or Griot's cutting pads and matching compounds you can eliminate defects pretty quickly and almost effortlessly.
    If you go Rupes I would spend the extra and get the Mark II
    2015 F-150 Crew Cab Lariat
    2016 Chevrolet Camaro 2SS
  6. #16
    Super Member dcjredline's Avatar
    Mar 2012
    Upstate NY
    3,340
    I would say the FLEX (being forced rotation) makes it different than a "normal" DA and long throw. The long throw will have advantages over a normal DA but will still stall. The biggest problem for me is my GG6 stalling, why would I buy something else (for alot more money) that will still stall?? Id take the 3401
    "Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"...aim4squirrels
  7. #17
    Apr 2015
    PGH, PA
    1,482
    The stalling issue on the long throw isn't a big deal like some people make it out to be, just relevel the polisher/pad
    Or attack curve half way top..then half way bottom..or like I said earlier, massage technique
    I'd rather come out of detail feeling less strained
    They both do the job, just take different skill sets to master
    With the 3401 it is important to keep level/flat so it doesn't vibrate or walk on You.
    ..I'm using the stock 5.5 BP with mine
    Some say it's easier with the 4in..
    I tend to.have issues when I get to middle of roof/hood and rocker panels
    Got the hang of using it elsewhere though
  8. #18
    Jun 2012
    Arlington Texas
    3,982
    I own and have plenty of time on both. They are both great machines. Both have different issues if you don't keep the pad at the right angle. Different, but they both do have issues. My preference is definitely the long throw.
    I also agree that the stalling issue with the long throws is blown out of proportion. I have no problems at all with my 15 Mark II. My G21 stalls once in a while. It's not a big deal.
  9. #19
    Mar 2015
    133
    As I mention previously, if you learn the correct way of using long throw, curves or conclaves won't be an issue. It's exactly what nothingface mention, half way up half way down and learn how to twist your ankle a bit, all problem solved. And once you learn it, nothing more pleasant than using them, smooth, powerful, and finishing superbly. The last thing is that there are nothing 3401 can do and long throw can't.
  10. #20
    Super Member VISITOR's Avatar
    May 2007
    9,729
    Quote Originally Posted by DaveT435 View Post
    G21
    awesome polisher...
  1. What's in the box? NEW Griot's BOSS 15mm & 21mm Long-Stroke Polishers
    Last Post: 11-18-2020, 11:23 AM
  2. Replies: 3
    Last Post: 11-26-2019, 12:53 PM
  3. How to lubricate the shroud on long stroke polishers
    Last Post: 04-17-2019, 02:13 PM
  4. Review: FLEX XFE 7-12 80 aka The FLEX 3" 12mm Long Stroke Orbital Mini Polisher
    Last Post: 07-30-2018, 01:38 PM
  5. Replies: 9
    Last Post: 02-15-2017, 06:24 PM
