Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Sep 2015
    6,281
    Re: How much more aggressive can I get?
    Using good products such as sonax line cut and finish will give you the edge of perfecting paint along with the advice from Mike Phillips.
    Sep 2015
    6,281
    Quote Originally Posted by pdqgp View Post
    I'm assuming you have a standard DA Polisher like a Porter Cable or Griots? vs a forced rotation one like the Flex 3401?
    As noted above by Mike, it's imperative that it's spinning/rotating for full correction. and performance. Perhaps slow down your arm speed. Another key piece I'd toss out there is for you take your time and be very measured with your technique in the beginning so you know exactly how to proceed going forward. Arm Speed, number of passes, type of pad and pressure all play in. Track it closely so you know what works and how much you need. I keep notes and pics on ALL the vehicles I do so I can better estimate things down the road.
    Here's a before an after of a Camaro I just did. Relatively hard clear coat but this was done with HD Adapt with a little Meg's Ultimate Polish mixed in as it really helps extend the working time. I'm ran a Flex 3401 with Orange Hybrid Force pads, 4 passes and that is what I stuck with on this car. Wasn't aiming for 100% correction based on the package I sold, but of course I will take as much as I can get. Overall most areas were darn near 95%+
    Any before and after pics of yours? Happy to help! Looking forward to seeing the progress. Also, don't beat yourself up fixing it 100% this go-round. Take your time, enjoy, but remember you can and likely will polish it again down the road and it can be after reading up and trying to products, etc. My personal car wasn't 100% for the first crack at it. Part of the fun is learning along the way.
    BEFORE:
    AFTER:
    Better view outside with a real camera vs cell phone:
    looks great and great advice for him.
  3. #13
    Oct 2016
    This is a picture of the test spot on the hood. It got rid of a lot of the water spots and oxidation, but the swirls are still there.
    How much more aggressive can I get?-img_20161122_141225-jpg
  4. #14
    Feb 2016
    157
    If you are looking for any products to try the griots boss fast correcting cream with a microfiber pad leaves excellent results. However you need multiple multiple microfiber pads as they hold heat more than foam pads. Try doing another pass sometimes it takes multiple passes to achieve results you want.
  5. #15
    Oct 2016
    The roof looked rough before.
    How much more aggressive can I get?-img_20161122_141144-jpg
    It looks good from here, but it's dark now. The real test will come tomorrow when it's sunny out
    How much more aggressive can I get?-img_20161122_170305-jpg
    I think I just need some practice with the DA and the correct amounts of product on the pad.
  1. More aggressive pad? Or more aggressive compound?
    By tone357 in forum Auto Detailing 101
    Last Post: 12-28-2015, 10:17 PM
  2. How to get more or less aggressive?
    By fett701 in forum Ask your detailing questions!
    Last Post: 05-31-2015, 11:58 AM
  3. What's more aggressive?
    By 11Silverado in forum Auto Detailing 101
    Last Post: 05-30-2015, 08:13 PM
  4. Factors that affect how aggressive or non-aggressive a product is...
    Last Post: 06-16-2011, 03:40 PM
  5. How aggressive
    By buster in forum Auto Detailing 101
    Last Post: 03-10-2008, 10:43 AM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
