Wax/sealant problem: need advice.
This is my first post here.
I've got a small problem. I just spent quite a lot of time and effort on my black MR2 Roadster to try to get rid of some swirls/cobwebs and generally polish it up for the summer. Here's a pic:
Here's what I did:
1) Wash & Dry
2) Clay with Meguiar's Bar + Quik Detailer
3) Menzerna Intensive Polish using PC 7424 and orange light cutting pad
4) Menzerna Final Polish II using PC and white pad
5) Wash & Dry
6) Klasse All-in-One (hand applied)
Now here's where the problems arise. After the Klasse, I put Wolfgang Deep Gloss Sealant on the car: 3 layers of it over the course of a few days. I knew that the Wolfgang had to sit on the car for 12 hours or so between coats.
After the three layers I topped with P21s.
What I didn't know (because the Wolfgang bottle has no instructions at all--bad Wolfgang!) but have since learned is that the Deep Gloss sealant needs to be left on the car for 30 to 45 minutes at each application. I was just wiping it on and wiping it off. D'oh!
So now I'm guessing I don't have the sealant protection I thought I did and just have the P21s over the Klasse (and maybe a little Wolfgang). Also, as it was my first time using the PC polisher, I realize now that I didn't do as good a job with the swirls as I might have.
What would you do to rectify this?
Would you:
1) Start over from scratch (no pun intended), including clay bar, intensive and final polish, etc.?
2) Wait until the wax stops beading water and then start from scratch?
3) Wash it with some sort of wax-stripping shampoo (which one?) and then start again beginning with the polish?
4) Something not mentioned?
I assume that putting Wolfgang Sealant on over the P21s is a no-no.
Thanks for all advice.
You are correct, do not put the sealant over the wax. Something you could do is Klasse AIO. That would strip the old wax off, and then you could go back to perfecting your polished surface. Remember to spend 3-5 minutes on each section @ a high speed (5.5-6). Your car looks great, and hopefully it all works out for you.
BTW, welcome to the forums!
Originally Posted by abrcrombe
You are correct, do not put the sealant over the wax. Something you could do is use a cleaner wax. That would strip the old wax off, and then you could go back to perfecting your polished surface.
Thanks! Can you recommend a cleaner wax?
Is the idea that I apply the cleaner wax and then:
1) polish
2) sealant
3) wax?
If you want to best of the best, and have time to do it - start over.
Start with Final Polish II. If finish looks fine already - skip AIO, and go to straight to Wolfgang sealant. Let it dry to a haze, how long - will depend on where you live in. Be sure to let sealant cure for 12 hours between each coat.
My mistake, cleaner waxes are more of a 1 step process than a cleansing tool.
You could remove the wax using AIO, then finish polishing, wash (if you are obsessive compulsive), then sealant and wax
Hmmm. OK, so is there any harm in starting over from scratch the way supercharged recommends? In other words, beginning with a re-clay? Isn't frequent claying going to mess things up?
Also, I didn't realize that AIO would strip away other waxes and sealants. Is it certain that after AIO and can just recommence polishing?
What kind of clay are you using? Pinnacle Ultra poly clay can be used as aften as nessesary...be sure to use a lot of lube.
If you just clayed the car I don't see why you would need to do it again. You could just repolish and then seal and after it is fully cured and you have all the coats you want applied then you could top with a wax if you choose or just leave it with the sealant. BTW where is that pic taken?? It looks like Scotland or someplace in the UK. Welcome to the forums Ernie Ball. Is that your real name or did you take it from the guitar strings? lol
I don't think you will need to clay again. I mean if you have the Pinnacle Ultra Poly, you can give it a whirl if you would like. Doubt any contaminants have adhered to the surface in this short amount of time.
Klasse All In One Polish changed everything about the way people polished cars. Klasse All In One Polish will remove oxidation, minor swirls, old wax, and other surface blemishes; leaving a beautiful and deep acrylic shine.
http://www.autogeek.net/klasseallinone.html
I think polishing will also help remove wax if AIO doesn't get it all.
Not my real name.
The pic was taken in the Wicklow Mountains, about 20 minutes from where I live in Dublin, Ireland.
Basically, I'd clay to get rid of all the stuff I just spent days putting on the car!
Think I'll get some of the Ultra Poly clay and do this:
1) AIO
2) Clay
3) Polish
4) Sealant
Should I apply more AIO after the polish or not?
By Real Riders in forum Ask your detailing questions!
Last Post: 08-02-2014, 05:51 PM
By Rez90 in forum Ask your detailing questions!
Last Post: 05-01-2013, 06:41 AM
By ChrisGT in forum Ask your detailing questions!
Last Post: 12-27-2011, 02:51 PM
By The Critic in forum Auto Detailing 101
Last Post: 12-12-2011, 10:07 AM
By ml13 in forum Auto Detailing 101
Last Post: 12-06-2009, 10:14 AM
26 | 27 | 28 | 29 | 30 | 31 |
