Results 1 to 10 of 10
    Sep 2014
    524
    Questions about Car-Pro Hydro2 lite
    1) Is this simply an RTU of the original version; simply a pre-mixed 1:6 RTU product?
    2) Does it perform equally to the original Hydro 2?
    3) Using either version, how many ounces of mixed product will one use on a standard sedan?
    4) lastly, I don't know why I hadn't seen this before, but I've seen videos where people use this as a Spray and Wipe product; meaning no power spray after you apply it. has anyone used this method with good results?
    I know, a lot of anal questions, but that's a genetic problem I inherited, LOL
    Thanks in advance
    Sep 2015
    6,281
    Re: Questions about Car-Pro Hydro2 lite
    Even if you get hydro lite rtu you may have some streaking.others claim they do and don't.I use for wheels that's it.The Gyeon wetcoat streaks alittle so I apply it like a spraywax no water.
    Sep 2015
    6,281
    Never mixed per dilution ratios so I can't help you there.
    Super Member rlmccarty2000's Avatar
    Dec 2013
    Fitzgerald, GA
    2,002
    1. Yes
    2. Yes
    3. Depends on how you spray it.
    4. I've never tried it as a spray and wipe. The directions say activate with a strong stream of water.
    Sep 2014
    524
    Quote Originally Posted by rlmccarty2000 View Post
    1. Yes
    2. Yes
    I appreciate the responses so far. The video from Car-Pro shows an application method os Spray and Wipe: No watet rinse; so I was curious if anyone has tried it.
    Here it is at the sister site
    CarPro Hydro2 Lite Touchless Silica Sealant 1 Liter (Ready To Use)
    Super Member KBsToy's Avatar
    Jul 2011
    SW...Pa
    1,490
    Lite / wet coat --- rinse , rinse, rinse
    Super Member CarolinasFinestDetailing's Avatar
    May 2011
    Charlotte, NC
    1,556
    Quote Originally Posted by glfnaz View Post
    Yes
    Yes
    Depending on sedan size and if you're sealing wheels as well, I usually use around 2 ounces.
    If you want the correct way to apply any CarPro product, consult CarPro-US site. Corey takes the time to give plenty of information about product and directions.
    Thanks in advance
    See bold.
    Carolina`s Finest Detailing - Charlotte areas preferred CQuartz Finest Reserve & GTECHNIQ Crystal Serum Ultra coating center. STEK/Suntek PPF
    www.Carolinasfinestdetailing.me
    Junior Member Svended's Avatar
    Nov 2016
    United Kingdom
    32
    1) Hydro2 lite is the RTU product of Hydro2.
    2) yes it performs just the same.
    3) Typically they say around 100-120ml per midsize car however I use around 150-170ml per midsize car.
    4) I've never used them as a spray on and buff off. Saying that I do and have used Hydro2 and Wetcoat by spraying on a couple of panels, wiping in loosely with a damp cloth and pressure rinse to activate and then wipe dry and move to the next couple of panels as streaking can be a problem if not properly rinsed or left on for more than a few seconds in a warm climate.
    Typically these products need pressurised water to activate so as to separate the carrier from the product onto the vehicle. Regular hose pressure water apparently gives less durability so something to bare in mind.
    If at first you don't succeed have a pint of Guinness and a very large Irish whiskey, think about it then try again, repeat till either the job is done or you are done.
    Super Member Avi@CarPro's Avatar
    Mar 2011
    544
    1) Is this simply an RTU of the original version; simply a pre-mixed 1:6 RTU product? yes its RTU diluted already
    2) Does it perform equally to the original Hydro 2? Yes at high dilution ratio
    3) Using either version, how many ounces of mixed product will one use on a standard sedan? i think about 150ml like 5 ounce
    4) lastly, I don't know why I hadn't seen this before, but I've seen videos where people use this as a Spray and Wipe product; meaning no power spray after you apply it. has anyone used this method with good results? Yes we show that, you can use it same as Reload or spray and wipe product , works well too.
    Thanks in advance
    see my replies to you.
  10. #10
    Sep 2014
    524
    Thanks for all the replies.
  1. CarPro Hydro2 Lite
    By tim500 in forum Auto Detailing 101
    Last Post: 07-11-2022, 05:47 AM
  2. Beadmaker over Hydro2 Lite?
    By josefdoc in forum Ask your detailing questions!
    Last Post: 05-22-2019, 05:24 AM
  3. CarPro Hydro2 Lite - is this normal?
    By mightypudge in forum Auto Detailing 101
    Last Post: 06-02-2018, 09:00 PM
  4. How to use Hydro2 Lite
    By cdell in forum Auto Detailing 101
    Last Post: 12-08-2015, 09:23 PM
  5. CarPro Hydro2 vs Hydro2 Lite - cost difference
    By CaveRacing in forum Auto Detailing 101
    Last Post: 08-23-2015, 01:28 PM
