My Ford Fiesta is 6 years old. The headlight lens was quite yellowed due to UV damage. I removed the headlight myself and sanded it by hand (for hours!). There are only 2 brands of PU spar coatings here in India. I chose the cheaper one (Asian paints, quite decent quality). I took the headlights to a local spray shop and got it sprayed (mixed it myself on the spot, then gave it to him). I was careful about the ratio of thinner. The result was pretty good, the headlights look as good as new.
I let it dry/cure in direct sunlight for 2-3 days. It has been 15 days since then, but I am not putting the car cover back on (which is a necessity here due to dust and rains, I don't own a garage currently). When I tried rubbing the car cover LIGHTLY on the headlight, it got scratched easily! I just placed the cover on top of headlight and moved it up and down a little (simulating the movements of putting, removing and adjusting the cover repeatedly). Then I tested it with a dusty microfiber cloth (just for testing), even that results in scratches!
For some reasons, the coating is too delicate. I can't leave it like this, I need to use car cover regularly.
I don't know what to do now. AFAIK I have two options:
1. Go the the spray shop and get the automotive clear coat (2 -3 layers) on the headlight. I have no idea if it's scratch resistant or not.
2. Put 100% transparent headlight film.
BTW I am unable to find 100% transparent films online, all of them are tinted/colored. Can I install the transparent films which are used for car windows instead? Will it need a hot gun to install on headlight and will it be safe for the coating?
Thanks in advance.
