P21S Paint Cleanser Polisher Settings
Hi guys,
I'm hoping someone can answer this quickly for me before I seal and wax my car tomorrow. I have some P21S because I don't plan on polishing my car this time around, but I am not sure what pad + speed I should use with the cleanser. I have a GG6 polisher, and white, orange, blue, and black flat pads. I'm already planning on using the blue and black for my DG105 + Collinite 845 so I'm kinda hoping I can use the cleanser with white pads?
Thanks
I've used the P21S paint cleanser with a machine, forget if it was my PC or GG6.
Anyway, IMHO & IME the product will work better by hand. What I mean is, I remember having to use a lot of product to keep the pad from drying up quickly. So, the pads gummed up quickly.
Looking back (it's been quit a while), I prolly should have primed the pads with some DI water.
Anyway, if yr going to do this - you just want to use whatever speed so the pad spins slowly. Any heat will dry out this product quickly. I would do 2 passes at the most.
A white LC polishing pad should be fine.
Re: P21S Paint Cleanser Polisher Settings
I actually came across a blog that said to do speed 4-5, but it sounds like I'll just waste a ton doing it that high. Thanks for the tip!
I think P21S recommends hand application. I normally use a MF Applicator or foam wax application to apply.
http://www.autogeekonline.net/forum/...x-cleaner.html
I ran my GG6 on a white pad on speed 3, and had no problems with the P21S drying up quickly. Definitely noticed a big difference after using it. Just applied DG105 + 601 and taking a break before throwing on the Collinite.
I forgot how sore the DA makes my arms and back.
If you did it by hand, you would have to take the next day off.
Any kind of a paint cleaner I would use no more than 3 or 4 on a da polisher. No need for anything more. Just let the product do the work. I typically use poorboys pro polish as just a cleaner and typically just do it by hand as needed. If I need a little cut or need to be slightly more agressive I'll use my PC with a polishing pad but typically don't find myself going that route
I agree.
Just to add a few more comments...
Technically paint cleaners are for removing light surface dirt staining and other light surface impurities. They prep the paint for the application of either a wax or a synthetic paint sealant.
If it were me, I would apply by machine using a soft foam polishing or finishing pad. Use a speed setting that maintains pad rotation but nothing more. Apply to a single panel and then wipe off.
Down the road, after you use up all your P21S Paint Cleansing Lotion, pick up a fine cut polish. A fine cut polish will do everything a paint cleaner will do and more and leave a nicer looking finish. For all the time and work it takes to apply a paint cleaner might as well apply a fine cut polish.
By Darion in forum Product Reviews
Last Post: 09-13-2013, 04:18 AM
By swanicyouth in forum Auto Detailing 101
Last Post: 05-23-2013, 07:56 AM
By KneeDragr in forum Product Reviews
Last Post: 10-26-2011, 08:48 AM
By trhland in forum Auto Detailing 101
Last Post: 10-02-2007, 06:56 PM
By klumzypinoy in forum Auto Detailing 101
Last Post: 02-26-2007, 03:05 PM
26 | 27 | 28 | 29 | 30 | 31 |
