How to clean this.
My last customer had these spots on driver window sill.
I tried APC, rubber cleaner, nothing worked.
I hoped gtechniq c4 would cover it but didn't work either
Any tricks?
Please like my page
Jae @ ONYX Detail Garage
Re: How to clean this.
Maybe try some rubbing alcohol on it i am not sure never had a problem like that i am no professional either but good luck
It's not dirty.
The UV protection coating is oxidizing. It analogous to clear coat failure on paint - except it's fake rubber.
Solution Finish should revive it.
Is that trim rubber or the hard plastic?
Originally Posted by Hoytman
Lol. I had to read that twice. I thought I misread the op. I have the same spots on trim as well. Tried everything I had to throw at it. Made it look better but didn't last long. I used the mothers back to black (non aresol). Worked the best surprisingly but spots reappeared after a week orbso
I second swanicyouth, Solution Finish is probably your best bet:
http://autogeek.commerce-search.net/...-trim-kit.html
MK7 GTI (stage 3-500whp) / Audi B8.5 S4 (dual pulley-430awhp) / Mercedes C43 AMG (JB4-380awhp)
I would still recommend cleaning the trim, rubber or plastic, with the Mothers HD Trim cleaner product I referenced, then proceed with Solution Finish...
...and then I'd top the Solution Finish with something like Wolfgang WETS, or Ultima Tire and Trim Guard...used as regular maintenance...even if bi-or-tri monthly. You'll be amazed at the results.
Coatings are another option if that's your fancy...still cleaning with Mothers HD Trim cleaner, Solution Finish, then something like a coating of Dlux.
Then again...lol...there's always the first option I mentioned...if you're brave. LOL!
I would use APC before solution finish. In my opinion Mothers leaves a bit to much residue to clean up prior to using solution finish. IPA wipe prior to using solution finish for either cleaner used.
I've had APC leave residues on paint that had to be polished off per Mike Phillip's personal instruction...both Meguiars APC+ and OPC at 1:10 for both. So, if there's a concern about residue, then I'd be concerned with all3 products. However, residue from the Mothers product I mentioned hasn't been an issue for me (because I use wash afterwards with soap and water then rinse)...like many have not had issues with APC residue like I did. In either case for me, I don't let any of them dry on the surface and I rinse, and rinse, and rinse. There's always the option of using one after the other and IPA before using a restorer/protectant.
By Dunkaroo in forum Auto Detailing 101
Last Post: 09-10-2020, 07:29 AM
By jmeyers278 in forum Auto Detailing 101
Last Post: 11-23-2017, 09:56 AM
By Pritch in forum Ask your detailing questions!
Last Post: 06-01-2015, 08:07 PM
By gatoman39 in forum Auto Detailing 101
Last Post: 06-11-2011, 10:48 AM
By Bags in forum Auto Detailing 101
Last Post: 04-26-2007, 10:53 AM
