Please help! helmspar urethane headlight restore yellow tint
Hello I have been trying to do the helmspar clear urethane with about 25/75 mix 25% helmsapr and 75% paint thinner and each time I do a car the lights have a slight yellow tint to them so I assume I'm doing something wrong?first I sand 800/1000/2000/2500 wet,then I polish by hand with automotive polish.Then I wipe clean and add the urethane helmspar and I think its this step where the yellow tinit comes in as the helmspar is yellow?maybe I should use mineral spirits or maybe I shouldn't polish?or maybe I have the wrong helmspar urethane??I got it at home depot and think its for wood but I don't know whats causing it but I like wipe on clear coats if I cant fix this problem could I take a crystal clear enamel clear coat and spray it in a cup then take a blue towel to dunk it in and apply?I don't want to use spray on because of the extra masking and stuff?I have a ton of this helmspar left and another person wants there headlights restoresd please help me fix this problem.
Re: Please help! helmspar urethane headlight restore yellow tint
I used the aerosol.That product is garbage for headlights and it won't last.I use to have Mercedes Benz account,and I must of sprayed 60 eclass and clk.a lot of them were come backs.why don't you prep the lights then polish them with nothing,then protect them with a sealant.If you are stuck on using that don't dilute it.Get some black foam wedge sticks in the paint section at HD and spread it on evenly.
The reason I did the helmspar,cause there was a guy there doing service dept cars and used cars.He showed me just before they threw him out.
Did the helmspar get him fired?
I don't remember this going back in 03.
Mineral spirits not paint thinner. Also it's a 50/50 mix. I have done this to a lot of lights including my own. I guarantee it for one year. My jeep is parked out side in direct sun light all day. Its been well over a year and they are not as shiney as when I first did them but they still look great. Here is part three of a video series I did explaining my method.
https://youtu.be/hpmnZOK2-KI
Nice!
Thank you.So paint thinner would cause the yellow tint?Are you pretty sure that's the reason I hope this is the case it wont let me put a pic up of the helmsman can but it looks like what everyone uses.do I need the oil based or water based?I think I have oil.anyway I will buy mineral spirits and thanks a ton I hope this is what works.
I doubt if the paint thinner was your issue. Paint thinner and mineral spirits are very similar and in some cases exactly the same thing. The two terms are used interchangeably at times. It really depends on how the manufacturer labels their product. I've actually seen cans of "Paint Thinner" with the words "mineral spirits" in smaller letters and parenthesis right below Paint Thinner on the face of the container. Kind of like waxes and sealants. What's a wax and what's a sealant?
If you use either mineral spirits or paint thinner as your thinning agent then you would use oil-based Helmsman. If you were using the water-based Helmsman then you would use water as your thinning agent.
Most of my comments in this and my previous post are simply an "educated" speculation based on my experience with the Helmsman in other applications. Like I said earlier I have never done the Helmsman headlight restoration. But one thing that is not speculation on my part but rather fact, is that the water-based Helmsman is clearer than the oil-based Helmsman.
By zlman in forum Auto Detailing 101
Last Post: 05-17-2014, 08:38 PM
By HotRod in forum Show N' Shine
Last Post: 03-27-2014, 09:27 PM
By Rav777 in forum Auto Detailing 101
Last Post: 02-15-2012, 04:15 PM
By Shinystang in forum Show N' Shine
Last Post: 07-07-2009, 07:18 AM
By Curtis Rose in forum Off-Topic
Last Post: 06-03-2008, 09:07 AM
