Results 1 to 10 of 10
    Jul 2016
    Bare aluminum rims with acid spots around rivets/bolts - please help
    I've learned my lesson on using detail spray on uncoated aluminum rims. Unfortunately, I didn't wipe all the detail spray off and it left parts of the rim "milky" with spotty white discoloration from the acid.
    I did search the forum and found an older thread that recommended Powerball Mini MD and Powermetal Scratch Removing Polish. Is this the best solution today? I also have closely spaced rivets/bolts around the whole inner portion of the wheel. The hexagonal bolts have a sharp edge and I am concerned that it will rip apart the Powerball or any similar product. The Powerball also may not be able to address the small areas between the bolts.
    Any suggestions would be greatly appreciated?
    Nov 2015
    Los Angeles, California
    13,765
    Re: Bare aluminum rims with acid spots around rivets/bolts - please help
    What kind of detail spray did you use?
    Just call me Mr. Mom
    Dec 2009
    STL and SoCal
    767
    I'm curious of the spray detailer as well - none of them (that I'm aware of) are acid based. If product just dried on the rim surface, try applying some more, and wiping it well. That usually removes any dried product.
    As for the PowerBall Mini MD, it's designed to operate at <300 RPM. Low speed will not damage the ball. Damage almost always comes from too high of operating speed, or using a ball with dried polish on it - it needs to be cleaned after each use, and allowed to air dry before reassembly and storage.
    Jul 2016
    I used Meguiar's Gold Class Quik Wax or M-Tech detail spray. The discoloration looks like those I have seen on pictures here of aluminum rims with acid damage but I could be wrong. I tried rubbing the area with PowerMetal polish by hand but it had no effect.
    Would the exposed rivets not shred the PowerBall?
    May 2009
    4,837
    I don't see why the Powerball Mini wouldn't work around the rivets but personally I use the Mothers Powercone. I have a client that I polish his wheels twice a year and use the Powerball, powerball mini, and power cone. If you use too much polish it can fill in the rivet heads so don't forget to clean it out.
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    What was used to wash the wheels?
    Super Moderator Bobby B.'s Avatar
    Sep 2009
    2,355
    Hmm... Spray Detailers shouldn't have acid in them. Maybe an acid based wheel cleaner caused the discoloration on your bare aluminum rims? Try using the Mother Billet Metal Polish with the Mothers PowerBall to polish the surface of your rims. Good luck!
    Mothers Billet Metal Polish cleans and shines billet, forged, and finely cast aluminum, brass and all polishable metals. Professional detailers,
    Junior Member jimd@mothers's Avatar
    Feb 2014
    Quote Originally Posted by 924RE View Post
    "had no effect" -- did the applicator turn black?
    Can you post some photos?
    Mothers Polish
    Customer Service & Technical Support
    jimd@mothers_dot_com
    Super Member Rsurfer's Avatar
    Jan 2007
    14,095
    Sounds like the OP used an acid based wheel cleaner.
  10. #10
    Jul 2016
    Sorry it turns out the wheel is not bare aluminum. It is Speedline with a clear coat or lacquer coat on the rim which may explain why there was no black residue when I rubbed the PowerMetal polish on the affected area.
    The wheels have not been washed or sprayed with any wheel cleaner, only the Meguiar Quik Wax and M-tech detail spray was used.
    The bolts/ rivets have a star shape and sit above the surface of the rim (not embedded in the rim) so I thought these might tear apart the Powerball or cone. Are there smaller Powerball-like attachments that can get into small/ tight spaces?
  1. DLUX on bare aluminum wheels getting water spots
    By RZJZA80 in forum Auto Detailing 101
    Last Post: 01-26-2020, 03:15 PM
  2. Wolfgang Uber on bare aluminum rims
    By C5Longhorn in forum Wolfgang Car Care
    Last Post: 12-28-2016, 12:34 AM
  3. Iron X on bare aluminum
    By KillaCam in forum Auto Detailing 101
    Last Post: 01-20-2013, 01:11 PM
  4. How to clean bare aluminum?
    By shoeless89 in forum Auto Detailing 101
    Last Post: 02-12-2012, 02:18 AM
  5. Aluminum rims ruined by acid...
    By Kristopher1129 in forum Auto Detailing 101
    Last Post: 09-02-2011, 01:56 PM
