Super Moderator
Re: RUNNING BOARDS ON 2012 X5 35i STAINED, NEED HELP AND DIRECTION
Are they Aluminum? If they are Aluminum try using a good metal polish like Wenol, Menzerna, Mothers and Flitz.
If it was me, I would not polish them - maybe only as a last resort. Since its BMW, I can almost guarantee there is some type of coating on them. Those little rubber nubbys will make it very tedious as well.
If it was me, the first thing I'd try is Trix from CarPro. This is because it's a solvent based cleaner (removes almost anything that can be removed) and it has an iron remover in it. It looks like some of the staining may be oxidized iron to me embedded in the finish.
Another thing I would try is a Magic Eraser. But, I would do a test spot first.
They are anodized aluminum, do not polish them. Use a strong apc and brush.
Probably aluminum with a coating. I would try simple green at 4 to 1 and a softer wheel brush.
Bill 1234
2004 audi a6 quattro (traded).
2015 Ford Escape 2.0l ecoboost 4WD
I removed the knobs to clean these running boards belonging to GL500. It only took a couple of hours for each side. I believe BMWs are similar
Dennis, how were you able to remove the knobs? Could you please show me the steps? I believe it may be similar on the X5.
Mike =, whats an APC? I have no idea. I am detail novice, forgive my ignorance.
Mike, what's an APC? I have no idea what the APC is. Forgive my ignorance. I'm a detail novice.
Dennis, what did you use to clean it?
By jackb88 in forum Ask your detailing questions!
Last Post: 06-02-2018, 08:34 AM
By pilotpip in forum Auto Detailing 101
Last Post: 02-18-2016, 11:38 PM
By bonedr in forum Auto Detailing 101
Last Post: 02-21-2014, 04:53 PM
By bluegoose in forum Auto Detailing 101
Last Post: 02-21-2013, 12:02 PM
By NYCLR3 in forum Auto Detailing 101
Last Post: 08-11-2011, 05:07 PM
