Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    Feb 2012
    Pinnacle Black Label stained trim
    I recently took the time to use my PBL surface cleansing polish and then applied the surface coating, but noticed that there is some significant staining - white streaks on plastic trim. It seems like both the cleansing polish and surface coating create this problem and I have not found any good way to get it off. Has anybody else experienced this and what did you to do fix it?
    Super Member ronkh57's Avatar
    Aug 2009
    3,392
    Re: Pinnacle Black Label stained trim
    Coating doesn't create stain. The polish may if left on plastic without wiping it off fast enough..........
    Unfortunately I haven't a clue how to get it off now, since it sounds like you coated over it........
    Feb 2012
    I used my DA polisher to apply the surface cleansing polish and I'm sure that is how I ended up bumping up against some of the trim. The coating was applied with the Lake Country coating applicators which is much more accurate along edges, so I don't THINK I coated over all of it. Would a trim restorer cover it up?
    Aug 2010
    New Jersey
    15,171
    Quote Originally Posted by cbuxton5200 View Post
    Nah, ya gotta clean it off. Try some APC and a soft brush, or some mineral spirits. Just be careful if the coating hasn't cured yet those cleaners may take it off the paint.
    Oct 2009
    493
    Some say using a pencil eraser works.
    Super Member Octopiston's Avatar
    Mar 2016
    Ft. Worth, TX
    287
    The mckee's coating prep polish does too. I cleaned it off quick, but it kind of looks like water spots. I used a brush and apc to try and clean. I even tried a dressing to see if it would help. It deminished, but still shows. I'll try some other fun stuff next.
    Aug 2009
    3,392
    Mar 2016
    Ft. Worth, TX
    287
    Had mine masked amd removed for this step so I could clean to the trim in prep for a coating.
    Super Member TroyScherer's Avatar
    Sep 2009
    Ohio
    1,912
    Questions:
    * Does the PBL surface cleansing polish or any other polish say in the directions say to use it on trim as a cleaner?
    * Did you do a small test spot first in an unseen area before doing all the trim?
  10. #10
    McKee's 37 Product Support
    Jan 2011
    7,265
    Bad news: your trim is stained and it's going to require some elbow grease to clean.
    Good news: you learned a valuable lesson and will (hopefully) spend a little extra time in the future taping off the trim.
    I'm a big fan of this product from MOTHERS: Mothers Back to Black Heavy Duty Trim Cleaner
  1. Pinnacle black label ceramic trim restorer
    By Mike Hoekstra in forum Auto Detailing 101
    Last Post: 01-09-2021, 11:50 AM
  2. Review: Pinnacle Black Label Ceramic Trim Restorer
    By acuRAS82 in forum Product Reviews
    Last Post: 01-31-2020, 10:00 AM
  3. Review: Pinnacle Black Label Ceramic Trim Restorer
    Last Post: 12-09-2019, 10:57 AM
  4. Pinnacle Black Label Ceramic Trim Restorer Mini Review
    Last Post: 10-29-2019, 07:59 AM
  5. Pinnacle black label trim restorer
    By PA DETAILER in forum New Car Care Products
    Last Post: 09-28-2019, 04:30 PM
