I'm still not sure in what situation I would choose either a Microfiber pad or a foam pad.
Is one better for specific things? Or it is just a question of preference?
I use meguiars MDX cutting pad whenever foam cutting pad + rubbing compound isnt enough or taking long time to cut and I need little more boost on cutting power.
So I know with a regular orange foam pad on a DA its fairly safe and you can get some some minor scratches etc. If I cant remove some marks/scratches with that should I try a microfiber pad OR use the next step up from an Orange pad?
Thanks
In the Lake Country lineup, I believe yellow is the next step in aggressiveness with their foam pads.
Theres more than one way to skin a cat here. There are so many great pad choices on the market today. Personally, I use MF pads for cutting, then finish with foam.
Carolina`s Finest Detailing - Charlotte areas preferred CQuartz Finest Reserve & GTECHNIQ Crystal Serum Ultra coating center. STEK/Suntek PPF www.Carolinasfinestdetailing.me
