Only one test spot?
Is it safe to assume the whole car has the same level of defects throughout?
I recently did a test spot on the hood of a 1972 Roadrunner and was happy with the pad and compound combination.
Then i soon realized the the right side of the car came out flawless but the right side took a more aggressive approach.
Any input would help
Re: Only one test spot?
On your car did you change pads from side to side? Was the car ever repainted? Either way you can always check your work as you go and not wait until your done and be disappointed
Yea i checked while i went was just very confused as it was my first time experiencing it and i went with a new primed pad per panel.
Car was repainted very poorly.
Vobro has some good qualifying questions and may be some reasons you got different results side to side. Whenever i encounter different conditions i do another test spot to find what will yield the same results over the entire vehicle. This new and additional test spot includes the info learned from the 2-4 i already did before i started. For example, i recently had a customer with extreme water spot/etching on the passenger front quarter panel. To get the same results over the whole car i had to change it up to a more aggressive approach to get the same results to match the other side. Takes maybe 5-7 minutes or so and doesn't really slow me down too much.
Now, did i remove a little more paint off that trashed section? Yup! But i note it in my customer database. The basic concept of removing the least amount of paint to give the customer what they requested and are paying for is what i always follow.
Last Post: 09-24-2019, 08:41 AM
By runrun411 in forum Auto Detailing 101
Last Post: 08-04-2015, 04:54 PM
By BennyHFP in forum Auto Detailing 101
Last Post: 05-19-2015, 08:22 PM
By HUMP DIESEL in forum Auto Detailing 101
Last Post: 11-20-2014, 02:56 PM
By Slava in forum Show N' Shine
Last Post: 12-23-2009, 12:06 PM
