Dislikes: 0
Cleaning engine bay?
Let's just say at 111k 04 bmw 545 and 3rd owner it was never cleaned or washed or anything? I had tons of problems with my 545 from leaks to timing issues. Now that it's ok to drive I want to clean the engine since I can see grease and other liquids all over the engine. What can I use it to clean it nicely? Can I use the local wash pressure hose with soap? Is there any place on the engine I should not touch? Coming from Hondas and toyotas motors I just pressured washed it and I went on!! But this bmw is def a very delicate motor!! So what do you guys recommend I do?
Super Member
Re: Cleaning engine bay?
Do at your own risk. I have never had any real problems but have heard of people that's have.
I would get a good citrus degreaser like 3D Orange 88 degreaser and a detail brush if it is as bad as you say. Spray 4:1, agitate with the brush and clean up with an old wet towel or rinse areas I wasn't worried about with a low pressure spray of water. An all purpose cleaner will work too, just not as well. I'm not a fan of petroleum based cleaners, but they do work.
Some will go all out and rap up everything they are concerned about with Saran Wrap, foil, tape, or all of the above first to be cautious.
____________
"The more answers I seek, the more questions I find."
From my point of view...I'd stay away from using any form of high pressure wash. There is just too much of a chance to get that one lonely bit of water in something.
Using a de-greaser, various brushes etc, then just let the hose flood the water and gunk off. From the sounds of it you may have one big mess, so maybe do the final wash over something other then concrete or asphalt.
You may want to look at the various "engine cleaners" (like Gunk) to bust through the real bad stuff.
Good luck...
Bill
In dog beers, I've only had one.
if it's a must cover the maf sensor alternator coil packs if any.Gunk is fine if you can deal with the smell.I personally would use a non caustic apc with a lot of manual agitation and it's cheaper.I have seen guys dump water full blast with a hose and also a pressure washer.some have luck and some don't.Pick your poison,I personally use a pressure washer on a low psi setting like 200 psi or lower and repeatedly look for areas that need more attention rather than blasting it in one shot.cover fuse box Gd luck.
Super Member
I never did like the smell of the regular Gunk. I found a citrus based OTC one a while ago that worked really well and didn't stink, but then I never could find it again later in stores. That's what originally got me looking into citrus based degreasers. They work really well.
____________
I used Chemical Guys Orange Degreaser at 5:1 on an '02 Civic's engine that had never been washed and it came out great. I used a parts cleaning brush and a flag tipped brush as needed and avoided the air intake, alternator, and computer.
What makes you say that?
Beware of those giving suggestions without evidence of their results.
Toyota forums really warn against pressure washers these days unless you really seal up electronics areas. Also, any place it can get into light fittings, etc.
I use purple power, brush bad stuff (rare) and rinse with a garden hose sprayer or just a flowing hose.
Super Member
Super Member
Funny cause the dealer I do work for mainly buys Toyotas and I have been using a pressure washer on his cars since 2015 and its over 50 cars Yaris, Camrys out my butt hole, Corollas too, bunch of Lexus also. Never had a single problem with any of them.
Most cars today have the entire engine bay covered by a big plastic cover and you have very very little chance to get anything into anywhere sensitive. Obviously dont hold a pressure washer 15degree nozzle 1 inch from any connectors or anything but you CAN use a pressure washer safely on engines. Its mostly drama and overly cautious people saying dont.
"Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"... aim4squirrels
Post Thanks / Like - 1 Thanks, 2 Likes, 0 Dislikes
SWETM thanked for this post
Similar Threads
By aliitp in forum Auto Detailing 101
Last Post: 08-15-2016, 06:57 AM
By Sicoupe in forum Auto Detailing 101
Last Post: 05-11-2016, 04:42 PM
By twitchcvma3-1 in forum Motorcycle Care
Last Post: 01-24-2015, 08:48 AM
By Texarkana in forum Auto Detailing 101
Last Post: 09-22-2012, 09:35 AM
By bk2nrml in forum Auto Detailing 101
Last Post: 06-01-2011, 03:39 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
28 | 29 | 30 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 |
Bookmarks
