Re: Garage lighting suggestions
Originally Posted by indianaryan
Shiny, is this the Philips bulb you said you are using?
Correct. Also I was mistaken, the bulbs I have are not 86 CRI, they're 85 CRI.
What I have (all from Home Depot) are these:
They sell them in 2-packs or in cases of 10.
I went to Home Depot and found the lights you're talking about. They're cheaper than I was finding online, so that's a relief. I noticed that the 10 pack of bulbs are slightly different though, which is strange. Both are the Daylight Deluxe Alto II T8 bulbs, but the 10 pack is only 82 CRI and 2750 lumens. Maybe I'll just stick with 6 of the 2-packs.
Shiny, since you know what you're doing electrically, I have a quick question. Would you recommend wiring all the lighting on the same circuit as the garage door opener? I'd rather not mess with the circuit box because I have no electrical expertise, and that would also mean I would have to run conduit from the box up the wall through the ceiling (I have attic space above the garage that I was planning on running wire in). I figured if it's ok, I would wire everything from the outlet that the garage door is plugged into right in the middle of the ceiling.
You did a nice job with the lights! It sure helps...
A couple of ideas:
Maybe get the lights closer to the wall on the side to help get better lighting on the sides of the car?
Maybe running the wires in pipe, or at least staple them?
Also, they make a different kind of box, that I think it would have work better, they are called "old construction boxes" they have 2 small "legs" on the sides that come out and bite on the drywall, so they are a lot simple to mount since you don't need to mount them next to a 2x4.
Enjoy your set up!
Thanks ROMEO. I appreciate your feedback.
I agree it will help if I move the lights closer to the wall. I was trying to get them on the inside of the garage door railing, but I don't think it will be a problem to fit them between the railing and the wall.
I might just staple the wires to the ceiling. That's gonna be the easiest.
I thought about doing the old construction boxes, but since I had the attic space above I wanted to nail them into the studs. I don't think it was that much more work to do it that way. I will have to do an old construction box for the light that was there originally though, since there is no attic space there.
Interesting... I didn't notice that with the 10-pack I picked up, and unfortunately I already took that box to be recycled. I'll have to go look at the lamps and see if there are any different part numbers between the 2-pack ones and the 10-pack. Looking at them all running, I can't tell any difference visually.
I know you've already done the work, but yeah the lights being on the circuit with the garage door opener would be fine. That's how mine are set up as well and I've had zero problems, even when I also run a large fan and my radio from the same circuit. 6 shop lights and an intermittently-run garage door opener aren't even close to making a 15A circuit break a sweat.
From your pics, I see that your ceiling is a couple feet higher than mine. That is going to affect the effectiveness of the lights you put in there since being farther away from the vehicle you're working on will allow the light to disperse more, making less of it actually usable as task lighting.
I'd say you'll either need more fixtures in there to get it even brighter, or you could hang the six you've got now from longer chains to get them closer to where you're working. Sure, that will leave the upper portion of the walls and ceiling darker than they already are, but since you're not working on a tall vehicle that extends into that space it shouldn't matter much. Just depends what you want to spend..... and chain is cheap.
Looks great so far though!
Thanks for the feedback! I did a little research and found that running the lights on the same circuit would be fine, so I went ahead and did it. Turns out it worked!
Since the fixtures are only $10 a piece, I think I'll end up adding more lights. The sides of the car could use some extra lighting for sure. I think I might add 4 more lights, 2 on each side, and place them between the garage door railing and the wall.
BTW, I found 1 box of 10 bulbs behind several other 10-packs that looked like it was probably an older model of the daylight deluxe bulbs. It actually had the same specs as the 2-pack, except it was rated for 36,000 hours instead of 24,000. Not sure why, but I went with it and they look exactly the same.
thanks for all the info, went out to my local home depot and changed over to the t8 6500/85s and holly molly, what a difference, i still have the old lights over the tool bench and it is incredible the difference between the two, thanks again and good luck to everyone with their projects. For very little money, what a difference.
Loving Life in my 2010 Crystal Red Grand Sport! "scrib13"
gotta chuckle, the pics of indianaryan in the sweatshirt and snowcap, it is just hard to imagine here in south Florida, he looks like he is trying to rob a bank. I really do not mean any disrespect and not trying to be mean, it just struck me as funny, sorry but sure glad your project is going well!!
The lighting looks great, and I just added new lights to my garage as well. Do you ever work with the garage door open? I thought about mounting lights the same way you did, but with the garage door open, the door would cover some of the lights.
By Dandy98 in forum How to Articles
Last Post: 11-10-2016, 06:30 PM
By BitterGreg in forum Auto Detailing 101
Last Post: 06-09-2015, 04:24 PM
By 05RLS2 in forum Auto Detailing 101
Last Post: 06-08-2011, 12:13 PM
By 05RLS2 in forum Off-Topic
Last Post: 05-07-2011, 10:17 AM
By Indy YZF in forum Auto Detailing 101
Last Post: 01-07-2011, 02:13 PM
