was looking for a cheap way to hang tools & came up with this. it was pretty simple to do & cheap enough. had to enlarge holes in angle iron to insert fitting pass the first groove(nice & snug). then you'll be able to clip it on the skinny groove to hold it from slipping out. then I took 5/16 x 1 1/2 '' washers & opened them up to make a clip. I drilled the 5/16'' center to the dia. of the first groove. then I cut the slot the same size, so I could slide it in. this will pin the tool from sliding out. I also etched the edge of the washers & bent them up. this will give you a grip to pull them out. gotta say it works pretty good. just lift the weight of the tool up & pull the pin. thanks for reading.
Carlo
