Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Super Member Jeremy1976's Avatar
    Apr 2015
    978
    And so it begins! Diamond plating.
    Sent from my SM-G935V using Tapatalk
    Nov 2015
    Los Angeles, California
    13,806
    Re: And so it begins! Diamond plating.
    What's the description of that particular sheet? Is it "tread plate"? Reason I ask is because it doesn't seem to be the high gloss reflective variety "diamond tread plate" or is it just my phone view?
    Sent from my iPhone
    Nov 2015
    13,806
    Correction: I believe it's called "tread brite"
    I worked for an aluminum company for several years a while back and I'm testing my memory.And so it begins!  Diamond plating.
    Sent from my iPhone
    Super Member fly07sti's Avatar
    Sep 2013
    SF Bay Area, Cali
    2,939
    Niiiice. Can't wait to see it all done up.
    Jul 2013
    Apex, NC
    1,283
    My buddy did the same thing. He works at a HVAC/sheet metal fabrication company, so he got the sheets at close to wholesale price. He went all the way up to the ceiling. He loves chucking things at the walls and nothing bad happening. I've wanted to do the same thing to my garage ever since. His panels had a plastic protective film on the top side that he pealed off after installation. They were shiny underneath.
    Apr 2015
    978
    Sent from my iPhone
    That is correct my friend! It looks a little weathered and not super bright or shiny. Should match my Kobalt cabinets pretty good.
    Apr 2015
    978
    Quote Originally Posted by DBAILEY View Post
    Sounds nice! I am going 4ft up the wall all the way around, but the wall that joins the house with all my cabinets and detailing stuff on will be fully plated top to bottom.
    Stuff is not cheap. Right around $100 a panel.
    Nov 2015
    13,806
    Is that .125 aka 1/8th inch thick? Or is it .063? Or did you go heavy duty and get .188?
    Sent from my iPhone
    Apr 2015
    978
    Sent from my iPhone
    I believe it is .125. I had a sheet up by the mat station if you remember. That piece was super shiny and much thinner in comparison to this stuff. I will have to repaint above where that old piece was from taking it down. No big deal.
  10. #10
    Nov 2015
    13,806
    Quote Originally Posted by Jeremy1976 View Post
    Sounds about right. I remember that thin .063 tread brite like it was yesterday.And so it begins!  Diamond plating.
    .125 inch is solid for what you're doing. It can easily handle your boy going directly at it with a bat a few times with no damage at all. Lol.
    Sent from my iPhone
  1. Diamond plating
    By Jeremy1976 in forum Auto and Garage Accessories
    Last Post: 09-19-2016, 08:50 PM
  2. Zinc plating
    By Circa40 in forum Auto Detailing 101
    Last Post: 07-02-2014, 11:31 AM
  3. Diamond plating polishing?
    By MikeN in forum Auto Detailing 101
    Last Post: 08-30-2013, 08:21 AM
  4. Mother's wheel cleaner screwed my Bullet's chrome plating :(
    By torque1989 in forum Ask your detailing questions!
    Last Post: 07-14-2011, 11:45 PM
  5. What the best approach to polish diamond plating?
    By Juztang in forum Auto Detailing 101
    Last Post: 05-13-2007, 08:27 PM
