I did a headlamp restoration the other day. The steps and things used is as follows:-
1. 800 grit sandpaper
2. 1000 grit sandpaper
3. 2000 grit sandpaper
4. Purple foam wool with Menzerna PF2200
5. LC orange pad with Menzerna PF2200
I wet sanded the whole headlamp and polished with the purple foam wool initially. However there is still a slight haze to the headlamp. I then took out the orange pad and did a further polish. Looks good but I cant seem to remove the scratches caused by the 2000 grit sand paper to a perfect flawless finish. The scratches can be seen under direct lighting. I went back with the orange pad and still I cant remove the scratches.
Now the question is. What went wrong? did I not sand enough? or the products Im using is not suitable?
