Re: Flex Precision Pads 1 inch 2 inch 3 inch
This is very great news!
Any chance this meeting will be broadcasted?
How 1" pads goes on PE-14 (I suspect alright, but don't hurt asking)? Is the 1300rpm 'lower' speed of PE-8 too much for an 'all-around' spot tool?
I always see PE-14 for it's 600rpm more appealing to me (DA refinishing guy), but I want a 'mini tool' for that precision / surgical buffing we are all crazy about.
The pads are gorgeous and very much needed!, but
please, Mike, sell me (in or out) PE-8 tonight!
Good luck,
Thanks you very much in advance,
― Isaac Newton
Originally Posted by Setec Astronomy
I wonder how long it's going to take for someone to take one of these
and try these pads and backing plates on a DA?
2 seconds sound right?
But I wonder about a 8mm throw on a 1" pad & a 7-8 pounds machine.
& Tato,
Mike doesn't sell stuff, that'd be Nick.
No... this is my co-worker Trey and I taking the iVan to the local show and standard routine now is I do live demonstrations on one of the cars attending.
Two weeks ago I buffed out all the flat panels on Don's Mustang but didn't tackle the thin panels.
Tonight I'll knock out all the thin panels.
I'll have Trey take some action shots showing the different pads in action.
The PE8 is actually the prototype given to me by Bob Eichelberg.
Why are they so tall?
I thought, "thin is in"
I am anxious to see if they can be used on a rotary without leaving holograms on soft paint
Great to have so many pad options coming on line
Thin is in.
That is when talking about dual action polishers that use a free floating spindle bearing assembly.
Gear driven tools don't really care if you use a thick or thin pad and I find normal foam pads, that is to say thick foam pads work great with both rotary buffers and the Flex 3401.
The entire reason thin pads work great with tools like the Porter Cable, etc. is due to less mass overall for the tool to rotate.
Also, less mass to absorb liquid. Thick wet pads rotate worse than thin wet pads.
Proof in the pudding is Meguiar's Xtra Cut MF pads, anyone ever measure how thin these pads are?
I know I've posted the thin is in - Meguiar's Xtra Cut MF pads analogy multiple times on this forum.
Also, my guess is there small diameter creates an illusion of the pads looking tall. If I place these pads next to most historically normal foam pads, that is non new trend thin pads, they will be about or the same thickness.
In my experience, the smaller the diameter the pad on a rotary the greater the chance to see a hologram or buffer trail in the paint. Not sure why this is but I've seen this for over probably as long as I've been using the rotary as I used to make my own small foam pads.
Could be with todays abrasive technology, stuff I didn't have in the old days, that small pads on a rotary buffer and holograms are now a non-issue. Black paint would be the way to find out.
Big picture is more like this... even if you are leaving some type of faint hologram on a thin panel like an A-Pillar... chances are by the time you apply a wax you'll never see it because it's a thin panel.
Holograms are seen easiest on flat panels, especially large flat panels.
Here's some holograms in a 1978 Trans Am vertical panel...
Awesome. Definitely will be picking these up with backing plates next week.
Originally Posted by Kamakaz1961
Woo Hoo!!! Will be placing my order! Just waiting for my Flex Kompakt to arrive!!
Thank you for the heads up!!
Just got a shipping confirmation e-mail on mine...................
i already have one of those because i have an old 2 7/8 rotary plate that was orig meant for my Makita but i mainly use it with the adapter and my DA. so the Flex BPs have the same size thread as a rotary? didn't know.
if that's case, i'm likely going to get the 1" BP and pads. seems really handy.
EDIT: oh, wait...that Flex IS a rotary. ok cool!
Wow, great demo on those pads, and great lighting in that tent!
By ejaf in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 11-17-2020, 12:20 PM
By Witty4242 in forum Product Reviews
Last Post: 02-16-2014, 11:49 AM
By Mike Phillips in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 11-23-2011, 12:37 AM
Last Post: 03-20-2009, 06:40 AM
By FMINUS in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 04-12-2007, 06:36 PM
