Hot Water Extraction in Cold Climate for Vehicle Interior
Hi Mike,
My name is Eric Grazer and I have a question about cleaning a vehicles' interior. I appreciate you taking the time to read my question and help me out!
Over the weekend I decided it was time to thoroughly clean my car so I rented a Rug Doctor from home depot with upholstery attachment. I believe this is commonly called steam cleaning but is technically using hot water extraction. I started cleaning at about 5pm when the temperature was 39 degrees with low humidity, but the temperature was expected to hit freezing by about 11pm. I didn't think of the amount of water I was using or that the temperature was going to go so low. I ended around 6pm and let the car sit. By close to 9pm I checked the car and the seats were still wet, I wasn't sure if they were going to dry or what to do so I drove the car for about a half hour with the heat on to try to help dry things out. I then came back, parked the car and checked it in the morning. In the morning everything seemed to be dry and okay.
My questions:
1) When I drove the car I was wearing clean clothes. They got a bit wet but were okay, but because I sat on the seat while it was still wet is that a problem for the cleaning/drying process? Would I need to redo the hot water extraction or as long as it isn't moldy am I okay?
2) What is the best way to use hot water extraction in the winter? If the temperature is below freezing will the seats actually freeze?
Thank you!
Eric Grazer
Re: Hot Water Extraction in Cold Climate for Vehicle Interior
Originally Posted by grazere
My questions:
Probably be okay. What you want to do after doing any extraction work is to get the interior dry as soon as possible. IN my Detailing Boot Camp Classes I show and we use an air mover to get the air circulating and this speeds up water evaporation.
See my tips article here,
Tips for using Extractors
Shop-Vac Professional Air Mover
Thank you!
Eric Grazer
If the temperature in the area/room/shop/garage you're working in drops to below freezing then I guess it's possible.
You can find out real easy, place a Dixie cup of water in the "area" overnight and see if the water freezes.
I'd recommend getting a space heater and turn it on about an hour before you start working as this will help to bring up the room temp.
Welcome to AutogeekOnline!
The only thing I use is dry steam. I've never seen a dry steam cleaner for rent but there are a few cheap options such as the vapamore or the mculloch. It is asking a lot for water to dry when it is this cold. As for redoing it, I would just leave it for now unless the seats still aren't dry. If that's the case, I would try to get it in a warm garage, see if there's anything you can manually dry, and once that's done, open the windows and put a few fans inside to circulate the air.
Wow, I didn't know AG was selling those air movers! Add to wish list!!
If you used proper extraction technique, there should not be a lot of residual moisture left in the carpet or seat
Make sure you are making two passes.
- The 1st one with the suction an sprayer on
- The 2nd pass with suction only, immediately after the 1st pass
So you are working one "strip" at a time
By hyu in forum Off-Topic
Last Post: 02-02-2015, 06:00 PM
By Angel_r24 in forum Auto Detailing 101
Last Post: 08-15-2013, 10:51 PM
By Mercedes350 in forum Ask your detailing questions!
Last Post: 08-04-2013, 11:00 PM
Last Post: 04-23-2012, 05:23 PM
By jlb85 in forum How to Articles
Last Post: 02-03-2011, 07:28 PM
