Re: Why do all of my tire dressings streak? Problem with bonding
Only thing else to try would be straight or diluted rubbing alcohol on a microfiber you do not want to rub down the tire, though if you have Carpro Eraser that would a better choice by doing this will get the tires 90, 95 even 100 percent clean, however if this don't work Ill leave the tire be or buy newer ones
Sounds like the tires aren't clean. I hear (but haven't used myself) that Tuf Shine tire cleaner is good and you clean and clean until it comes out white, which can take 10 cleanings.
Here's more that's geared towards the same cleaning theme:
"Be wary of the man who urges an action in which he himself incurs no risk." ~Joaquin de Setanti
You should keep in mind that the majority of tyre dressings are more like waxes than sealants - they leave a film which sits there rather than actively bonds.
I find that dressings on smoother surfaces, like the tyre in question, can be generally difficult. It is made worse by previous dressings which repel water (i.e. for water based dressings). So the recommendation of cleaning really thoroughly is a good one but my experience is that it is harder to get rid of silicones than detailers think (if it was that easy, why would bodyshops be so darned careful about silicones!?)? Beyond that, the use of solvent based dressings should be good, they will not be repelled by previous silicones since they will partially dissolve and spread.
First off, Wow, 2 normal replies from Bob
But what he is saying is correct. Clean it well, scrub it until the product turns brown, then rinse down and go at it again and again. Autogeek sells a DA brush for this too.
