Results 1 to 7 of 7
    Newbie Member mxmbulat's Avatar
    Aug 2014
    QC, Canada
    Unhappy Spots on the roof
    Greetings,
    I have a question on the nature and type of the attached white spots which I have found yesterday while working on my car (Honda Accord 2008 LX). They are found on the front side of the roof and it seems I can't take them off.
    Yesterday I decided to give a bit of care to our family car and specifically:
    – washed it,
    – used Mother's clay bar, which has removed most of the gunk,
    – used Griot's DA polisher with Griot's Machine Polish 3 (for a slight polishing since the car has not been worked, I guess, ever – I am the second owner),
    – used again the polisher with Griot's Sealant to protect the paint.
    The car is shiny now apart from these spots.
    I am enumerating all these steps to show that I have passed the area with the spots at least several times and no step has removed these spots.
    I found Mike's article on removing water spots but I am so uncertain on what type of water spots those might be if they are indeed water spots. I would really appreciate if someone could help in identifying these spots.
    Attached Thumbnails Attached Thumbnails Spots on the roof-spots-jpg
    In time out
    Mar 2013
    Los Angeles, CA
    4,845
    Re: Spots on the roof
    The good news is that the clay removed most of the gunk, this make me believe that the majority of he issue is above surface contamination
    You might try a cleaner wax
    You might try the steps suggested by MP on water spot removal
    You might try CarPro Spotless- water spot remover
    Lots of options
    Good Luck
    Post your "Afters"
    Aug 2014
    QC, Canada
    thanks. I am just confirming that these look as water spots and then I could work on them as per instructions found in that how-to article written by Mike. I always thought that my car does not have no water spots. Wrong was I!
    Super Member wdmaccord's Avatar
    Jun 2013
    West Des Moines, IA
    1,278
    I would say yes. These look like typical spots from an irrigation system that sprayed your car, then the water drops baked in the sun.
    2016 Accord EXL V6 w/Navi & Sensing - Black/Ivory
    2019 Acura RDX A-Spec - Black/Red; 2019 Acura TLX Base 2.4L - MSM/Black
    2008 CRV EX - Black/Black 2003 Accord EX V6 - Black/Tan
    In time out
    Mar 2013
    Los Angeles, CA
    4,845
    Even if it turns out to not be water spots....one of the suggested steps to correct WS will likely correct whatever it is
    Super Member Sicoupe's Avatar
    Mar 2013
    Oklahoma
    3,352
    Quote Originally Posted by wdmaccord View Post
    I agree.
    Aug 2014
    QC, Canada
    Thank you all. I will take care of this then.
    Taking care of Honda Accord 2008 LX
  1. roof top carrier on a vista roof
    By Hanet in forum Auto Detailing 101
    Last Post: 05-24-2019, 07:08 PM
  2. Suv roof
    By Zalmon in forum Auto Detailing 101
    Last Post: 06-06-2016, 07:56 AM
  3. Dodge Caliber Roof Black Plastic shows water spots
    By theamcguy in forum Auto Detailing 101
    Last Post: 08-07-2014, 09:12 AM
  4. Water spots on CR-V roof rails
    By akimel in forum Auto Detailing 101
    Last Post: 05-17-2011, 03:27 PM
  5. Got roof?
    By ExoticAutoDetai in forum Auto Detailing 101
    Last Post: 04-18-2011, 09:27 AM
