Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    Mar 2014
    Claying with Water Only!?
    Lately I've been claying by spraying water lightly from the hose. This seems to provide adequate lubrication. I've had instances in the past where this wasn't providing enough lubrication and had to use a lubricant. I like this method because it keeps me from having to wash the car again to rid the lubricant. Do you have any suggestions? I know it probably doesn't glide as well which can cause marring but in my recent experience it seems to glide almost as good. Thanks for any tips or suggestions. Just wondering if anyone else does this?
    In time out
    Mar 2013
    Los Angeles, CA
    4,845
    Re: Claying with Water Only!?
    Seems less convenient to me than using a spray bottle
    I am always leery of bumping the paint with the nozzle or hose itself.
    If you like water only, using it in a spray bottle seems more efficient and safe.
    Jul 2011
    Houston, TX
    259
    Nothing wrong with that. We do light polymer clays during rinsing on some wash packages.
    IG: #dailydetailer @htx_dailydetailer
    Nov 2009
    Pasadena, CA
    12,615
    I would never use water as a clay lube.
    '03 Corvette Z06
    Super Member tpr1634's Avatar
    Apr 2012
    South Jersey, just not far enough south
    1,160
    Quote Originally Posted by ZL1 Mark View Post
    Roger that........
    Apr 2012
    1,160
    Buy your self a bottle of onr and a gallon of distilled water follow instructions for mixing, cheap and it works.
    Attached Thumbnails Attached Thumbnails Claying with Water Only!?-image-jpg
    Super Member Jaretr1's Avatar
    Jan 2011
    Miami
    2,391
    Clay lubes dont leave a residue if you are wiping the car as you go. Water by itself does not have enough lubricity to be safe for claying without marring. Why risk it?
    Jun 2014
    I don't really feel that water provides the necessary lubrication needed to use clay as friction is needed. I personally would go with 2 ounces of onr with a gallon of water in a spray bottle . That will last a long time and reduce the possibility of marring the paint. Another alternative and this is what I do, is using the clay wash mitt with a gallon of water and two ounces of onr. I may have a little waste, but i can easy knock out claying an average sized car in about 30 minutes.
    Super Member GenesisCoupe's Avatar
    Mar 2013
    1,919
    Nothing great ever gets achieved without lubrication.
    CURRENT: Happily Retired
    PAST: Owner at Clean N' Shiny, Chicago Auto Pros
  10. #10
    Aug 2010
    New Jersey
    15,196
    Quote Originally Posted by brandon g View Post
    I almost always clay when I'm washing. Wash, rinse, resoap, clay, rinse. Some clays will break down a bit in the wash solution.
  1. Replies: 7
    Last Post: 07-19-2015, 08:54 AM
  2. Replies: 1
    Last Post: 11-14-2014, 08:04 PM
  3. Claying Lubricant or Soapy water ???
    By Webb in forum Auto Detailing 101
    Last Post: 05-04-2012, 02:40 PM
  4. Claying: Is soapy water just as good as quick detailer?
    By flektone in forum Auto Detailing 101
    Last Post: 09-05-2011, 03:55 PM
