Spot correction of Guards Red Porsche
I'm in need of some advice. I have an area on my rear deck that is marred but have no idea how it happened. I hit it with Megs UP but that didn't do anything except make it shiny. I'm reluctant to try anything too aggressive on it because I understand it's pretty soft so anyone have experience with Guards red?
'12 Ford F150 SCrew FX4 Red Candy Metallic
'19 AMG Mercedes GLC63 Selenite Grey Metallic
Re: Spot correction of Guards Red Porsche
Please post pix if possible , it might help you here fella .
I haven't been able to get a real clear photo of the problem. I'll try to change up the lighting and see what I get.
I did a Cayman S a few months ago and I used HD Adapt with a cutting pad You can see everything that I did here
Premier Auto Detailing by Evan: Porsche Cayman S Corrected and Coated
Test Spot Before:
Test Spot After:
Evan, nice job on the Cayman. I'm not familiar with the product you used, how does it compare to say, m105?
Nowhere near the cut of M105, HD Adapt would have the cut similar to Megs Ultimate Compound, but finishes like a fine polish. Where as UC would NOT finish down like a polish, especially not on soft paint. Its very pad dependant, so you can adjust its cut level by using different pads. For your Porsche, I recommend a green B&S pad with HD Adapt.
Try M105 on a polishing pad the follow that up with M205 or Ultimate Polish
I don't have guards red but mine is black (991), which is generally more soft and I can tell you that Menzerna SF4500 will be your best friend when it comes to finish out. I was getting marring with most other finishing polishes and once I used 4500, the paint was perfect. I paired it with Lake Country HydroTech pads (crimson) and it's a combination that I continue to use today. I still haven't found anything better.
By Slowcorrado in forum Show N' Shine
Last Post: 09-08-2018, 04:13 PM
By Oakes in forum Show N' Shine
Last Post: 12-17-2014, 12:48 PM
By cleanmycorolla in forum Show N' Shine
Last Post: 11-18-2013, 12:22 PM
By AndrewBigA in forum Show N' Shine
Last Post: 06-23-2013, 03:36 PM
By uniquedetailing in forum Show N' Shine
Last Post: 09-21-2011, 11:05 PM
