Results 1 to 7 of 7
    Dec 2013
    95
    Clay bar and Ironx?
    Should I clay bar and then Ironx or other way around? Or only one or the other?
    There is rail dust on my moms car.
    Super Member GreatAvalon's Avatar
    Feb 2014
    Manassas, VA
    614
    Re: Clay bar and Ironx?
    Iron-X, then Clay
    2012 Toyota Camry SE | 2013 Toyota RAV4 Limited
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by GreatAvalon View Post
    Iron-X, then Clay
    @OP:
    -This would be my product usage order as well.
    -How did you diagnose that your Mother's vehicle
    has rail dust?
    Apr 2014
    493
    On another thread I read, one poster experimented with the order, and found when he used Iron-X first, it was easier to clay and he got less contamination on the clay bar. I Iron-X a section, rinse w/ ONR solution, then immediately clay while car is still wet - saves a drying step.
    Super Member zmcgovern45's Avatar
    Sep 2012
    St. Louis, MO
    3,443
    When introducing new products and processes into your routine, it helps to think about the process logically...
    Consider the purpose of both products. IronX is used to remove bonded iron particles. Detailing clay is used to remove all bonded contaminates.
    If you were to use Iron X after claying, there would be very little (or hopefully no) iron contaminates remaining for the product to remove. With that being said, it would make most sense to use IronX first to eliminate the iron particles before claying, thus leaving less contamination for you to remove with the clay bar and therefore (hopefully) saving you time using the clay bar (or synthetic clay substitute).
    Hope that helps
    Retired Professional Detailer
    Super Member SATracker's Avatar
    Nov 2007
    San Antonio
    594
    Ditto everything said. I use Iron-X, and always before claying.
    Apr 2014
    178
    I just did my wifes crosstrek. It made the claying much easier. I clayed the whole car in about 40 mins and it felt smooth. I am polishing and sealing now.
    Sent from my SCH-I605 using AG Online
  1. Replies: 39
    Last Post: 11-04-2018, 08:35 PM
  2. IronX and IronX Clones - Fun Facts
    By Route246 in forum Auto Detailing 101
    Last Post: 08-28-2018, 04:46 PM
  3. Clay? IronX? heavy or light compound?
    By txmojo in forum Ask your detailing questions!
    Last Post: 03-31-2017, 09:59 PM
  4. Replies: 3
    Last Post: 02-11-2017, 04:31 PM
  5. Thoughts: IronX Snow Soap Over Traditional IronX?
    By TuxedoTaurus in forum Auto Detailing 101
    Last Post: 07-17-2014, 07:22 AM
