Re: crooked foam cannon what do i do?
Use some teflon tape on the threaded connection then loosen it enough to where its in the correct position. See if that helps.
thats what the guy at home depot told me to do. they didnt have the proper thread. wouldnt the thing leak water if i just use the tape?
would be best if i could find a proper attachment to fix this
on my karcher i do exactly what aerocleanse mentioned. make sure to use teflon tape so it doesn't leak...
It wont leak if you put the tape on,then snug it to where it sits properly. Be sure not to over tighten and crack the threads.
(Or you can hold your gat sideways! )
Sent from my SAMSUNG-SGH-I777 using AG Online
Gangsta Wash!
Originally Posted by Hazcat
Gangsta Wash!
I laughed way to hard
Teflon tape should prevent any leaks, and its cheap too. Getting a different adapter would be best, it depends on how much trouble you're willing to go though.
I always wrap threaded hose connections with teflon tape if there are not going to be undone after every use.
Not sure where that adapter came from (maybe they changed them), but the one AG sells/sold? Is female with brass threads.
Since its female, - and the you need a male/male pipe (brass), you now have 2 sets of threads you can tighten to clock the bottle right.
So, if Teflon tape doesn't help - get a female Karcher adapter.
u mean get this? male nipple connects to cannon and karcher attachment connects to other end of nipple and then attach to gun?
Brass Male Nipple Connector
Karcher K-Series Pressure Washer Fitting
By Speedie6 in forum Auto Detailing 101
Last Post: 03-23-2018, 08:14 AM
By JMak97008 in forum Auto Detailing 101
Last Post: 11-14-2017, 10:52 AM
By SON1C in forum Product Reviews
Last Post: 05-30-2016, 02:44 AM
Last Post: 10-25-2014, 04:21 AM
Last Post: 03-15-2014, 01:33 PM
