Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Junior Member Faris63's Avatar
    Jun 2013
    SoCal
    51
    Removing silicone from paint
    Hello guys
    I removed the front lip from my front bumper today and the piece attached by silicone. its PITA to remove I tried Goo Gone adhesive remover with no luck removing anything I also tried Klean-Strip Denatured Alcohol
    Any suggestions ?
    Feb 2012
    Ireland
    1,149
    Re: Removing silicone from paint
    Can you not manage to 'peel' a bit more of it away? Even with a sharp blade?
    Dissolving cured silicones is extremely hard work, especially large lumps like you have there. To achieve it, as it sits, would likely put your paint at risk so I would definitely recommend trying the manual approach before going to more chemical methods.
    Jun 2011
    2,711
    I would first try an assortment of plastic razor blades, or something similar that's plastic...well before moving on to a metal blade...very carefully...if at all.
    Bill
    Super Member Andr3wilson's Avatar
    May 2012
    Edmonton AB
    1,615
    Dissolving it will take a looong time. Heat gun, carefully blading and peeling it off is your best deal.
    Oct 2013
    Covington, LA
    102
    Ouch! Just put the lip back on.
    Super Member Shane731's Avatar
    Dec 2009
    Madison, AL
    3,498
    Are you sure it's silicone? Kind of looks like perhaps wheel bearing grease to me, or something similar to the stuff that somebody at the Honda dealer put in the sliding door tracks of my mom's Odyssey when it was in for a repair. Still scratching my head over that one. That looked like this:
    It was on the sliding track and the inside top of the sliding door (both doors). The only thing that worked for me (and didn't damage the paint) was rubbing alcohol (I used a 70% solution undiluted) and lots of microfiber towels. I think I went through at least a dozen. Go buy some cheap ones from Wal-Mart or Target, because you will have to throw them away. Note that this method still took a while.
    This is just my guess. I could be wrong. If it is silicone, I would try heating it with a heat gun and getting off what you can with a plastic razor blade, then try the rubbing alcohol. Either way, hope you get it fixed!
    Shane
    Super Member spiralout462's Avatar
    Dec 2012
    Eastern Shore, VA
    1,771
    plastic blades, putty knives and Tarminator would be my first approach probably. Maybe a little heat as well?
    Jun 2013
    SoCal
    51
    Thank you guys for the suggestions I'll try everything to get this off
    Aug 2010
    Fairmont, MN
    3,189
    I picked up a product a couple of years ago...De-Solv-It (brand) "Contractors Solvent" at my local Ace Hardware. The stuff DID remove silicone caulk (as it said it would). As I look at the bottle, $7.99.
    Just to add, I was working on the shower doors (that I installed) so I knew that the caulking was indeed silicone.
    Bill
  10. #10
    Super Member 02xtreme07SS's Avatar
    Oct 2011
    NorCal
    361
    That might not be silicone. It may be a polyurethane adhesive. If it is, it's going to be even harder than silicone to remove. This is what 3M recommends to remove one of their automotive poly adhesives:
    If sealant is already cured, removal is done mechanically with razor knife, piano wire,
    sanding or 3M™ Scotch-Brite™ Molding Adhesive and Stripe Removal Disc. This
    disc is available from 3M Automotive Aftermarket Division
    You might even be able to try this:
    3M Stripe Off Wheel 07498, pinstripe tape removal
    07 TBSS AWD 3SS (Black) - 09 TBSS 2WD 3SS (Silver)
  1. removing spot gloss touch up paint to expose original paint?
    By slacknh in forum Auto Detailing 101
    Last Post: 09-16-2012, 11:37 AM
  2. silicone dressing in paint shop
    By bukee in forum Ask your detailing questions!
    Last Post: 01-31-2012, 09:40 PM
  3. silicone wax
    By rjohnson67 in forum Auto Detailing 101
    Last Post: 06-26-2010, 03:23 PM
  4. Silicone Tire Dressings Bad!! For Tires And Paint!!!!
    By trhland in forum Auto Detailing 101
    Last Post: 12-12-2007, 04:26 AM
