Results 1 to 10 of 10
    Oct 2013
    911, we have a brake fluid emergency
    What's up guys! New the site in need of dome serious help. I recently got my wheels done in a PVD coating. Its a type of powdercoating done that gives an awesome shine. Have had the wheels done for about 2 months maybeeee.
    Car sat for a little while as weather was bad and life was busy so the car didn't get moved. Well finally got to drive it over the weekend and there was a puddle of brake fluid on the ground. Turns out it leaked all over the inside barrel of my newly redone wheel, eating through the clear coat with ease. When I popped the wheel off, this is what the clear looked like (see pic 1)
    It peeled up around the barrel with ease. Washed down the wheel twice, once with car soap and once with dawn to pull out any remnants of brake fluid out. The major flaking is off byt i can still scratch off more clear with my fingernail. This is what I am currently left with:
    The known process in doing these wheels states the clear is an acrylic clear. Well it appears that the brake fluid only penetrated through the clear and not to the actual coating itself.
    I'd like to know two things:
    1) Im assuming the haze of the clear means it is compromised. Is there anyway to wetsand the clear off and respray the inner barrel with duplicolor clear to prevent the clear from further infiltrating to the face of the wheel.
    2) Is there anyway polishing with compounds and a DA can restore this clear?
    Much thanks in advance!
    Attached Thumbnails Attached Thumbnails 911, we have a brake fluid emergency-uploadfromtaptalk1382548236861-jpg   911, we have a brake fluid emergency-uploadfromtaptalk1382548410502-jpg   911, we have a brake fluid emergency-uploadfromtaptalk1382548429301-jpg   911, we have a brake fluid emergency-uploadfromtaptalk1382548452314-jpg
    Super Member CDot's Avatar
    Aug 2013
    1,010
    Re: 911, we have a brake fluid emergency
    I'm not a pro, but the clear looks gone. You may be able to polish down before applying dupicolor, but in the areas you photo'd I'm not sure if you can bring that back.
    Super Member Dr_Pain's Avatar
    Nov 2012
    South Central, Louisiana
    2,196
    Sorry to say but the clear is gone as you mentioned and it is not advisable to try and polish the "powder coating".
    Acrylic clears are much less durable than the 2 part urethane clears and I am sure the break fluid had a field day, but the coating is chemical resistant (if in the same family as powder coating).
    Again, sorry to hear and sorry for not being able to provide you with a better advise than "get them stripped and redone"
    https://www.facebook.com/FlawlessFinishDetailing
    Dr. Claude Tremblay, Co-owner/Senior Detailer, Certified CQuartz FINEST Installer
    Super Member Vegas Transplant's Avatar
    Oct 2011
    Left Lane...Hammer Down
    4,446
    Quote Originally Posted by Dr_Pain View Post
    +1.
    That's a lot of work.
    Duplicolor Clear will not survive well in a wheel's environment IMO.
    Maybe pose the question on a metal finishing forum if you don't get satisfactory answer here.
    VT
    Quote Originally Posted by glen e View Post
    Super Member Pockets@PoorboysWorld's Avatar
    Jul 2009
    West Nyack, NY
    835
    Agree with all that was said
    Do you happen to have a picture of them before and the face of them as I'm looking into PVD rims for my truck =)
    Chris (a.k.a. Pockets)
    Warehouse Manager
    Pockets@poorboysworld.com
    (845)215-9700
    Oct 2013
    This is unfortunately what I expected. Is there anyway to help the clear lift off the undercoat?
    Crazy idea.....if the brake fluid didn't eat through the under layer, could I coat the rest of the inner barrel with brake fluid, then just wipe it away and do my thing with the wheel clear?
    Oct 2013
    @poorboys
    Attached Thumbnails Attached Thumbnails 911, we have a brake fluid emergency-uploadfromtaptalk1382558085099-jpg
    Oct 2011
    4,446
    Quote Originally Posted by Det_Riot View Post
    Crazy idea.....
    Indeed
    But on the flip side, you have nothing to lose.
    VT
    Super Member geekdout's Avatar
    May 2013
    hobe sound, fla
    370
    Really sorry to hear about your wheels, especially after seeing how good they looked. But look on the bright side at least you were not out driving the car with this potentially serious braking issue and had an accident.
    I am sure you can find ways of chemically stripping the wheel that are a lot more reliable, sorry I can't be more specific.
  10. #10
    Super Member Andr3wilson's Avatar
    May 2012
    Edmonton AB
    1,615
    For trying to sand and reclear, it's going to be really hard to match/even out the clear (using a spray can) for the wheels, you will always see it. Like it will technically work, but if you don't have much paint experience, it will fail in about a year or two.
    Do it right, and get them done properly!
  1. Clear bra marred by brake fluid spill - way to fix?
    By white98ls in forum Ask your detailing questions!
    Last Post: 07-18-2019, 05:46 PM
  2. How do I remove brake fluid from carpet
    By Ted Y in forum Auto Detailing 101
    Last Post: 04-05-2017, 11:41 AM
  3. Brake fluid on headlights??
    By Whitewater25 in forum Auto Detailing 101
    Last Post: 06-24-2016, 10:40 PM
  4. Brake fluid stained wheel
    By 2011 Kona Blue in forum Auto Detailing 101
    Last Post: 05-12-2016, 12:30 AM
  5. brake fluid as a quick detailer?
    By cannibal in forum Introduce Yourself
    Last Post: 12-27-2008, 02:51 PM
