Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Mike Phillips
    Guest
    How to apply Detailer's Paint Coating
    I recommend using the softest foam applicator pads you can obtain, you want a foam that is soft and gentle to the paint. It's a good idea to wear safety gloves anytime you're working with any car care chemicals as a safety precaution. Like my friend Renny Doyle says,
    "If it's on your skin it's in you"
    Here's Eric wearing black nitrile gloves, if you don't have any Autogeek stocks multiple sizes. Add some to your order to make sure you always have plenty on hand... no pun intended.
    Technique Tip
    Because dry foam does not glide over paint in a slippery manner, when first starting out, mist a spray of the Detailer's Paint Coating directly onto the face of the foam applicator pad, this instantly primes the pad and will make spreading the coating you spray onto the panel easier and safer to spread and work into the paint.
    Mist 1-2 sprays per panel
    Next mist 1-2 sprays of the paint coating onto the panel to be protected. Sprayer on the bottle does a really great job of atomizing the product just be sure pump the spray head firmly to force the liquid to properly atomize.
    Carefully spread the product out over the panel
    Use gentle overlapping circular motions to spread the product out over the panel to be treated and work the product into the paint till you see it disappear.
    Wipe panel before moving on to the next panel
    After treating a panel, carefully wipe any high points, which are really "excess product" off the surface. Give each panel a careful inspection as you're wiping and buff the panel to a high gloss, dry shine.
  2. #2
    Mike Phillips
    Guest
    Re: How to apply Detailer's Paint Coating
    If you found this article from a Google search or by searching the AGO forum, be sure to read this article too for all the information you need in order to prep your car's paint for Detailer's Paint Coating.
    How to use Detailer's Paint Coating Prep
  3. #3
    Super Member ryanbabz71's Avatar
    Join Date
    May 2010
    Location
    Avon, Indiana
    Posts
    785
    Post Thanks / Like
    Product is very easy to use and works great. Used it on my 2010 Silverado a few wks back. A few days later it rained while I was at work, came out after work and the water had sheeted off the paint after the rain stopped. The only way to tell it had been out in the rain was that the windows had some water spots. The paint was still visually clean with no waterspots at all.
    The technique tip above is essential. The first time I tried using it I had the foam pad grab and fly out of my hand.
    Ryan
  4. #4
    Mike Phillips
    Guest
    Quote Originally Posted by ryanbabz71 View Post
    Thanks for adding the above...
  5. #5
    Super Member rouxster's Avatar
    Join Date
    Oct 2013
    Location
    New Orleans, LA
    Posts
    231
    Post Thanks / Like
    Quote Originally Posted by Mike.Phillips@Autogeek View Post
    Mike, what kind of foam pad is being being used in the pictures above?
    Ryan
  6. #6
    Super Member RobertJ34's Avatar
    Join Date
    Nov 2013
    Location
    Orlando, FL
    Posts
    345
    Post Thanks / Like
    Quote Originally Posted by rouxster View Post
    They are using the "Gold Wax Finger Pockets"
  7. #7
    Super Member
    Join Date
    Jul 2013
    Posts
    269
    Post Thanks / Like
    Quote Originally Posted by RobertJ34 View Post
    This, possibly wearing a black glove underneath
  8. #8
    Mike Phillips
    Guest
    Quote Originally Posted by UglyBetty View Post
    Correct.
    Think about it. If you're using a chemical that some how has the ability to bond to paint and last up to three years. It's made from nano-ceramic glass particles, I think that implies very tiny particles, you don't want this on your skin.
    As my good friend Renny Doyle says,
    If it's on your skin... it's in you....
    No matter what coating you're going to use... add a box of nitrile gloves onto your order and work safe.
    They don't cost much and their like a form of physical health insurance to protect you on the outside as well as the inside.
    Black Nitrile Gloves
  9. #9
    Super Member GenesisCoupe's Avatar
    Join Date
    Mar 2013
    Posts
    1,919
    Post Thanks / Like
    Thank You for the article..
    So when you apply the actual coating, you are supposed to "buff" it off right away? Or let it sit for several minutes?
    CURRENT: Happily Retired
    PAST: Owner at Clean N' Shiny, Chicago Auto Pros
  10. #10
    Super Member cleanmycorolla's Avatar
    Join Date
    Apr 2012
    Location
    Pasadena, CA
    Posts
    3,805
    Post Thanks / Like
    Quote Originally Posted by GenesisCoupe View Post
    You buff off high spots, you should be applying it and it'll melt into the paint so to speak. It's not a buff off project, you spray, spread, and if it's not level buff the spot.
    Back to the full-time grind.
Similar Threads
  1. Can you apply McKee's paint coating on top of Hydro Blue?
    By geoguy in forum Auto Detailing 101
    Last Post: 10-13-2017, 09:59 PM
  2. Video: How to apply the GYEON Q2 Mohs Ceramic Paint Coating
    By Mike Phillips in forum Product Reviews by Mike Phillips
    Last Post: 05-01-2017, 11:01 AM
  3. When to apply paint coating?
    By MIsnowman in forum Auto Detailing 101
    Last Post: 07-31-2016, 10:56 AM
  4. Review: Detailer’s Paint Coating & Detailer’s Coating Prep Polish
    By Mike Phillips in forum Ask your detailing questions!
    Last Post: 12-29-2014, 07:55 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
