Re: How to apply Detailer's Paint Coating
If you found this article from a Google search or by searching the AGO forum, be sure to read this article too for all the information you need in order to prep your car's paint for Detailer's Paint Coating.
How to use Detailer's Paint Coating Prep
Product is very easy to use and works great. Used it on my 2010 Silverado a few wks back. A few days later it rained while I was at work, came out after work and the water had sheeted off the paint after the rain stopped. The only way to tell it had been out in the rain was that the windows had some water spots. The paint was still visually clean with no waterspots at all.
The technique tip above is essential. The first time I tried using it I had the foam pad grab and fly out of my hand.
Ryan
Thanks for adding the above...
I recommend using the softest foam applicator pads you can obtain, you want a foam that is soft and gentle to the paint. It's a good idea to wear safety gloves anytime you're working with any car care chemicals as a safety precaution.
Mike, what kind of foam pad is being being used in the pictures above?
They are using the "Gold Wax Finger Pockets"
Originally Posted by RobertJ34
This, possibly wearing a black glove underneath
Correct.
Think about it. If you're using a chemical that some how has the ability to bond to paint and last up to three years. It's made from nano-ceramic glass particles, I think that implies very tiny particles, you don't want this on your skin.
As my good friend Renny Doyle says,
If it's on your skin... it's in you....
No matter what coating you're going to use... add a box of nitrile gloves onto your order and work safe.
They don't cost much and their like a form of physical health insurance to protect you on the outside as well as the inside.
Black Nitrile Gloves
Thank You for the article..
So when you apply the actual coating, you are supposed to "buff" it off right away? Or let it sit for several minutes?
CURRENT: Happily Retired
PAST: Owner at Clean N' Shiny, Chicago Auto Pros
You buff off high spots, you should be applying it and it'll melt into the paint so to speak. It's not a buff off project, you spray, spread, and if it's not level buff the spot.
Back to the full-time grind.
By geoguy in forum Auto Detailing 101
Last Post: 10-13-2017, 09:59 PM
Last Post: 05-01-2017, 11:01 AM
By MIsnowman in forum Auto Detailing 101
Last Post: 07-31-2016, 10:56 AM
Last Post: 12-29-2014, 07:55 AM
