Leatherique application
Hello guys,
Once the Rejuvenator oil had enough time to work the seats, should i remove it before using Prestine clean ? Or just apply prestine clean on top to the rejuvenator?
Thanks
Re: Leatherique application
pristine is a cleaner not a topping. you will need the pristine to clean the soiled rejunevator off.
+1, although Leatherique say that PC leaves some protection behind, it's main role is to clean the RO from the surface.
After this PC can be used as a maintenance cleaner.
Also I think you would find it quite hard to remove RO without PC as it becomes quite thick & sticky.
When I used it I let the RO soak, sprayed the leather with PC, agitated with a soft brush, wiped with a hot, damp towel then dried with a clean, dry towel.
By kevinmfitz in forum Auto Detailing 101
Last Post: 06-17-2020, 04:31 PM
By jever009 in forum Auto Detailing 101
Last Post: 04-15-2020, 05:34 PM
By Jean-Claude in forum Show N' Shine
Last Post: 01-04-2014, 10:58 AM
By Rez90 in forum Ask your detailing questions!
Last Post: 08-24-2013, 11:16 AM
By 2K4CE in forum Auto Detailing 101
Last Post: 09-05-2011, 11:52 PM
