Tip: How to pull tape off car paint
Here's a friendly tip, anytime you're pulling masking tape or more specifically "painter's tape" off an automotive finish, pull it slowly and at an angle. This is even more important when working on,
- A fresh paint job - 30 days or less
- Any car with a re-paint
The reason why is to protect yourself from problems just in case there's any type of adhesion problem between the paint and the primer in the case of a single stage paint job or the clear paint and the basecoat for a basecoat/clearcoat paint job, and in some cases, between all the layers of any paint system and the surface of the panel painted.
Like this...
Pictures & Videos: 2003 Honda Civic Extreme Makeover - Duragloss
![](http://www.autogeekonline.net/gallery/data/1529/CoralsHonda021.jpg)
Always remove tape by pulling back at a low angle, don't remove tape by pulling it "up" and away from the paint...
(Don't ask me how I know)
![](http://www.autogeekonline.net/gallery/data/1529/CoralsHonda022.jpg)
How To Use The Cyclo Polisher
Here I'm making slow, overlapping passes in two different directions on the 5 speed setting which is the highest speed setting.
![](http://www.autogeekonline.net/gallery/data/1550/CycloShots009.jpg)
Front to back...
![](http://www.autogeekonline.net/gallery/data/1550/CycloShots010.jpg)
Side to side...
![](http://www.autogeekonline.net/gallery/data/1550/CycloShots011.jpg)
Now carefully pull the tape-off at an angle...
![](http://www.autogeekonline.net/gallery/data/1550/CycloShots022.jpg)
Here's before and after results...
![](http://www.autogeekonline.net/gallery/data/1550/CycloShots023.jpg)
![](http://www.autogeekonline.net/gallery/data/1550/CycloShots024.jpg)
![](http://www.autogeekonline.net/gallery/data/1550/CycloShots025.jpg)
Man versus Machine
Here's a safety tip that's a best practice to develop anytime you're using Painter's tape on automotive paints. When you remove the tape, pull it back at and angle, not straight up, off the paint.
![](http://www.autogeekonline.net/gallery/data/728/Lincoln037.jpg)
Re: Tip: How to pull tape off car paint
And unless you're trying to capture a DRAMATIC "Before & After" picture to show case what can be done to restore paint... don't buff directly on the top of the strip of tape.
I explain why in this article,
The LINE ---> How to avoid the line!
![](http://www.autogeekonline.net/gallery/data/1422/FlexVideo005.jpg)
Comprehensive as always, Mike!
I see swirls everywhere!!! ![Buffing](https://www.autogeekonline.net/forum/images/smilies/buffing.gif)
Mike and I cant stress this enough. Especially to the guys using the green 233+ painters tape. This stuff has incredible holding power and will pull off fresh paint.
I work in a body shop and use this tape for painting at work and at home for detailing. Anyways I have seen a few of my guys pull the paint straight up or straight back and it rips up fresh paint from the surface. Now they have to repaint....
There's another technique most of you know about but might not know the name for it... it's called,
Burning the tape
This is when you apply the tape to your shirt or pant leg first to reduce the stickiness and then apply the tape to the paint. Kind of like how like a fresh lint roller sheet is super sticky, but as you roll it over cloths to remove lint the stickiness falls off.
Anyway, I have a picture of this somewhere on the forum but the name of the technique is called,
Burning tape or burn the tape, or burning the tape
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png) Originally Posted by Mike.Phillips@Autogeek
Burning the tape
![Smile](https://www.autogeekonline.net/forum/images/smilies/smile.png)
And here's the link to the article on burning tape...
Burning Tape
I have also noticed from way back Mike, that you keep the Tape low to the body panel as you pull to remove.
I assume this also helps lessen the possibility of lifting paint as well, correct?
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png) Originally Posted by MarkD51
Yes.
Like I say in my classes,
Low and slow...
By HondaRon in forum Ask your detailing questions!
Last Post: 11-26-2014, 08:53 PM
By Washburn in forum Auto Detailing 101
Last Post: 06-18-2014, 07:10 PM
By wangotango in forum Auto Detailing 101
Last Post: 08-23-2012, 02:52 PM
By itzJoker in forum Auto Detailing 101
Last Post: 06-13-2010, 06:42 AM
By CherryMettallic08 in forum Auto Detailing 101
Last Post: 10-22-2007, 11:06 PM
26 | 27 | 28 | 29 | 30 | 31 |
