Re: Long Term Review Spar vs Opti Pro **PICS**
have to get some of that spar... that looks bad ass
Originally Posted by Part-timer
I am actually considering switching to the Opti-coat. So wouldn't polishing also cause the Opti-coat to come off, like the spar does?
No because the oc reacts with the plastic versus just layering on it. And get o-lens for headlights. Its supposed to have more uv inhibitors.
Opti-lens works best on a fully polished lens. Compared to spar varnish, it goes on very thin and clear.... does not streak or peel or fade. Drawback is that you need to restore the clarity of the lens by polishing and can't rely on the coating to hide much. But you end up with a much better looking, more consistent result IMO.
Delta's coating would be similar to using spar varnish. I think it's a lot easier to use than minwax, and works better/tougher/lasts longer.
As with all the "pro" coatings, both cost more than minwax, but it's worth the reasonable $ per job.
Hey Jrs, any updates on the test? Just did Opti Lens on two cars down here in south Florida so I'm anxious to see how they hold up!
How much does Delta's coating cost? I tried the OC and it shows every tiny sanding mark.......It didn't work so well for me.......maybe I could use OC over the spar?
Sorry my bad, been busy. I'll snap a few pics tomorrow. The last time I looked (about 2 weeks ago) the Opti-coat is holding but is showing some signs of breaking down. Its been almost 1 year.
In the meantime, i wouldn't hesitate to buy O-Lens. The results so far have been awesome.
I think Mr Fusion said, OC wont hide sanding marks and its wasn't designed to I'm sure. If you see sanding marks, its because you didn't inspect properly in between sanding stages before polishing.
I always try to cross hatch my sanding from stage to stage. So go one direction with your first sanding stage, then cross it with your next. That way when you inspect, if you see sanding marks going in the opposite direction you were just sanding in, you know you missed and need to keep sanding.
I'll also let u guys in on a little secret. I STOPPED SANDING HEADLIGHTS!!!! Yes thats right, i only break out the sand paper if there is some DEEP damage, or there's a previously applied coating like clear coat thats been delaminating.
I've been using those 3" purple wool pads with M101 on my PC and i promise it'll clean up the oxidation just as good as sanding. As a matter of fact, on 2 separate headlights that had delaminating clear coat, I've gone from Megs #500 sanding disks by machine, to #800grit by hand, to purple wool & 101 on my PC and its gotten out ALL the sanding marks in less time than sanding up to 2-3000 grit. So that means that your purple wool + 101 = up to #800 grit of abrasiveness, which is what I used to START sanding at on most headlights. I've saved so much time by doing this!
No worries. Sounds good man, thanks!
Updated pictures please!!!!!
Cars
1972 Chevy Nova
1994 Acura Integra
By TroyScherer in forum Product Reviews
Last Post: 07-06-2018, 08:33 AM
By Billy Baldone in forum Auto Detailing 101
Last Post: 10-06-2015, 09:53 AM
Last Post: 08-29-2012, 11:07 AM
By Mongoose in forum Show N' Shine
Last Post: 03-14-2011, 07:14 AM
