DP max wax question?
The directions read that it is wipe on wipe off, meaning do a panel at a time.
Would it be possible to do the whole car and then remove it with my portercable instead?
Which way do you prefer to use this wax?
I would not recommend you do that. Usually WOWO products are intended to be used just like that, wipe on, wipe off. If you leave it on there for too long, it can streak and or be a pain to remove.
Follow the directions recommended, you can remove the wax with your PC using a MF bonnet over a firm foam pad.
Most LSPs are ready to be removed when they dry to a haze. That said when a WOWO LSP hazes it is past the point of being ready to wipe off. If you do a test spot by applying Max Wax to a small section of paint and let it dry for the time you think it would take to apply it to the whole car, and it wipes off easily then feel free to follow through with your plan. Either way though, keep in mind, the dry wax you remove after several minutes isn't cured to your paint. Yet, the wax that is under that dried wax is going to cure to your paint. So the longer you wait to wipe off the longer the wax is just sitting on your paint not completely bonding and curing to it. You can't go wrong following a manufacturer's directions. And what is there to really gain by not wiping off immediately after applying?
Sent from my SAMSUNG-SGH-I897 using AG Online
Re: DP max wax question?
I always do the entire car then wipe off. I've never had a problem. Max Wax is one of the easiest waxes I've used.
Back to the full-time grind.
I have multiple cars, two black. I think I'll do the wowo on the 2013 avenger and full car with the '85 mercedes. Then compare which one turns out better.
Super Moderator
Same here, great wax and priced nicely!
This is how we apply all the WOWO pastes waxes for our garage projects. That is we apply to the entire car, (after the paint has been meticulously machine polished to perfection), and then carefully wipe the wax off.
It always wipes off super simple.
Does that include Fusion and Souveran? I always wiped off right away.
Thanks Mike
Larry
Thanks Mike
Larry
Yes.
Below is the link to the pictures of the 1959 Impala we sanded and buffed this last weekend and then machine applied Wolfgang Fuzion and wiped-off by hand after applying to the entire car.
Here's the application of Wolfgang Fuzion... I'll post the beauty shots in a few mintures...
http://www.autogeekonline.net/forum/...classes-2.html
By MartyK in forum Ask your detailing questions!
Last Post: 06-10-2020, 08:57 AM
By Miguelhz in forum Auto Detailing 101
Last Post: 11-29-2014, 11:28 PM
By drastic_detail in forum Auto Detailing 101
Last Post: 11-20-2008, 07:09 PM
