Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Super Member Rhudeboye's Avatar
    Mar 2010
    372
    Cant Remove these marks from door sill area
    They appear to be your average shoe scuff marks. I used power clean 3:1, let it soak a bit then wiped with mf. They lightened. Then i tried it at full strength and agitated with a bristle brush. The markswill not come out.
    Any ideas?
    Super Member Rsurfer's Avatar
    Jan 2007
    14,097
    Re: Cant Remove these marks from door sill area
    Magic Eraser, but do it lightly.
    Regular Member Dave Medvic's Avatar
    Oct 2012
    Warminster,Pa.
    132
    Never used Power Clean, but if it is the equivalent of Meg's APC then I'm surprised. Goof Off and Goo Gone may help here if your still trying diff. things. Also, 0000 Steel wool also used vey lighty with the Goo Gone should have an affect.
    May 2010
    Colorado Springs, CO
    466
    This is one of the few areas that I use a Magic Eraser along with APC, but use the eraser lightly.
    Mar 2010
    372
    Thanks Guys, I'll give the magic eraser a go when I get off work and post the results.
    Super Member Pureshine's Avatar
    Dec 2012
    Seattle
    4,774
    I'll tell you my secret lol I use blue scotch-Brite non-Scratch pad it doesn't scratch and 1z deep plastic cleaner. the combo works so great I can get it clean 98% of the time. You can also use the deep plastic cleaner on treated leather works better than any other cleaner I have ever used.
    Super Member Pinpoint_Precision's Avatar
    Jan 2013
    Fort Lauderdale, FL
    1,182
    If it is a scratch mark on that plastic, then I am not sure of anything that it will take it off. I've seen a lot times in some of my customer cars, we can make it look better with the black in the center but that's just about it. I would use magic sponge, maybe goo off like other fellow detailed mentioned here. Good luck.
    Super Member ScottB's Avatar
    Mar 2006
    South Florida
    18,803
    Majic Erasers work well as long as they are not scratches in the plastic. Some plastics have a bit of a pattern and need a little more work.
    Scott
    Jan 2013
  10. #10
    Jul 2013
    269
    I tried Goo Gone on something similar based on tips from another thread. It worked great.
  1. Door jam /sill ?
    By luckydawg in forum Auto Detailing 101
    Last Post: 10-20-2020, 06:34 PM
  2. Rubber on door sill
    By 2007M6 in forum Tricks, Tips and Techniques
    Last Post: 04-13-2015, 09:08 AM
  3. Light scrathes in aluminum door sill
    By XJL in forum Ask your detailing questions!
    Last Post: 01-08-2015, 09:56 AM
  4. removing scuff marks on door sill plastic
    Last Post: 06-30-2011, 08:36 AM
  5. Suburban Rubber Door Trim...Need to remove marks
    By Lilskeezer in forum Auto Detailing 101
    Last Post: 11-24-2009, 11:26 PM
