New paint job. Mild holograms
Just had my car painted changing the color. It was a quality paint job using Spies Hecker paint. The finisher put some mild holograms in the paint. Question. Can I buff the new paint just as I had been buffing the factory paint? I know that the new paint will never be as hard as what came out of the factory. I just want to make sure that I do not damage the paint while trying to get rid of the holograms. Here is how I do it
1) Clean paint (obviously)
2) Use my PC with LC 6" orange pad. I use Wolfgang Total Swirl Remover
3) Speed of the PC set to six. Moderate pressure making 6 section passes
4) Switch to LC white pad and use Wolfgang Finishing Glaze with PC speed set to 5
5) Do 4 section passes with moderate pressure and 2 passes at light pressure
6) Use WDGPS.
With the new not as hard paint is this still acceptable or do I have to change how it is done? thanks
Don
Re: New paint job. Mild holograms
Anyone have any advise?
Don
You would'nt want to use any wax/sealant for at least 30 days after a new paint job.
Paint Needs to Breathe=
(Vintage Mike Phillips circa 2004)
Actually most of the time clearcoats that are "aftermarket", are a lot more harder then factory. However there are some cases where they are extremely "soft". You should just do a test spot and find out. Test with a very low abrasive polish and pad.
Just make sure you don't use any glazes or waxes that would clog up the pours of the paint for at least 4-5 weeks.
Okay going a different direction. I will be using M105 and M205 followed by WDGPS. I think this will be the ticket with using slow speed and light pressure.
Don
Don
Use a "test spot" to dial in the process and products.
VT
Originally Posted by glen e
Don
You shouldn't need M105 on new paint with "mild holograms". As mentioned above do a test spot and use the least aggressive pad/product needed to get the job done.
Agreed^^ I don't know why people think 105 is a polish. It's a strong compound!!! heavy swirls and scratches need 105. Not light swirls and holograms.
There is fine scratching, holograms, minor RIDS, and some hazing due to incomplete buffing. All minor stuff. I just figured that the M105 did such an awesome job of removing a bird poo stain on my fresh paint, rubbing by hand, that using the M105 with my PC would make quick work of these defects. Instead of running the machine at 6 I would try it on 3 or 4. Instead of applying 15 lbs of pressure I was gonna try like half of that. I am also contemplating just doing it by hand. Seems like it would go quickly that way too. Then run the M205 with the machine. The M105 may be aggressive but wouldn't it also be the fastest and easiest approach?
Don
My thinking is why work hard with a polish when a compound will do the job faster and with less effort. Is this a poor train of thought? I am a newb at this stuff. I only do my own vehicles and only like once a year at that
Don
By dochawk in forum Ask your detailing questions!
Last Post: 12-30-2015, 08:14 PM
By One2nine in forum Show N' Shine
Last Post: 06-18-2014, 11:16 PM
By charlestek in forum Auto Detailing 101
Last Post: 10-01-2013, 09:12 PM
By Vossman in forum Wolfgang Car Care
Last Post: 05-16-2012, 06:41 PM
Last Post: 04-18-2011, 01:57 PM
