Re: Please HELP!!! Can my glass be saved....
Could it be the windshield wasn't entirely clean before you started? Did you clay before polishing? I think you can also try an LC Orange pad as long as you don't let the windshield get too hot.
Thanks for your reply. This was my driver side front door window btw. I cleaned the glass with glass cleaner several times but I did not clay it. I was thinking about trying the LC Cyan hydrotech pad.
Yeah, Corey/CEEDOG used a Cyan Hydrotech and it seemed to work ok for him. Could it be the pad wasn't exactly flat as you worked it and the scratches were made by the edge of the pad? I would think a drill is harder to control than your Flex.
From Mike P's thread: The Glass Cutting discs are hard and thin, that's their characteristic, just an observation, not a negative or positive comment. The point is they are thin and hard and glass is hard so one thing that helps a lot when buffing glass is to use the glass cutting discs with a flexible backing plate which helps make the buffing process smoother.
I kept the pads as flat as possible. The glass is curved a bit where I was working. The reason I used a drill was because I only have the GCP in 4" and I have a soft foam backing plate to use them with for more cushion. I'm so distraught over this I hope there's some way to get them out.
I found a video that shows the process with the Diamondite products. I'm not sure if they are Ceriumoxide based like Ceriglass.
Diamondite GlassWork Cleaning System - YouTube
The previous link was for cleaning. The following is for polishing:
Diamondite Glass Repair kit - YouTube
thanks for the links. I really wish I could get my hands on a LC foam glass polishing pad. I'm almost certain that would fix my problem. Which yellow pad or other foam pad do you think I should try otherwise?
I bought a LC foam glass pad a few years ago and it's not exactly a soft pad if that's what you're thinking. It's stiff and hard, unlike their polishing pads. It's more like their tangerine hydro pad foam than polishing pad foam, but stiffer, so I don't know how well it does curved surfaces. I still haven't tried it partly for that reason.
I don't know what this intermittent problem seems to be with with Ceri-Glass, but there used to be a Diamondite Glass Resurfacing Creme which according to Mike Phillips contained cerium oxide, but it hasn't been available for more than a year...I've never heard an explanation as to why it's no longer available. I used mine once on what I consider to be soft glass, using the LC hard glass pads, and didn't have any problems like the OP.
EDIT: Here is the page, but you can't find it through the menu: Diamondite® Glass Resurfacing Crčme
By JMPC in forum Show N' Shine
Last Post: 01-12-2015, 04:34 PM
By dcjredline in forum Wolfgang Car Care
Last Post: 05-27-2014, 12:38 PM
By rjdavis61 in forum Ask your detailing questions!
Last Post: 05-31-2012, 11:08 AM
By New Image in forum Off-Topic
Last Post: 01-03-2012, 06:37 PM
