Re: Wish I Found This Site Earlier!!!
Thanks guys,did some more reading here and tried the compound again
with the Buffer/Grinder.
Starting to learn about the right technique and waiting for the compound to
break down till it starts polishing more.
Three passes later the results are looking promising;
Just have to figure out the next step.
VT
Originally Posted by glen e
A good polish/finishing polish then a good coat of either sealant or wax for durability go sealant and for the extra shine glossybess go with a good carnuba wax although nothing sais u cant put the carnuba over the sealant. :wink:
When you have to make a choice and don't make it, that is in itself a choice. ~William James
The next step after compounding with a wool pad and a rotary buffer would be to switch to a less aggressive polish and a foam pad on a rotary buffer or something like a Flex 3401 or a DA Polisher. Just make sure whatever tool, pad and polish you're using is removing the swirls imparted into the paint by the fibers of the wool pad and the abrasives in the compound.
You always want to test out your system before you buff out the entire car to make sure you don't waste your time.
It's called the Test Spot and you would normally do this at the very beginning of the project so you already know each pad, product and process you're going to to from beginning to end.
How To Do a Test Spot
I also cover this in my how-to book...
Just an update;
Thanks again for all the tips,here's the reason I had to get it done.
nephew and his GF needed it:
[IMG][/IMG]
By Legaspi89 in forum Introduce Yourself
Last Post: 03-20-2012, 06:22 PM
By DealerDetailer in forum New Car Care Products
Last Post: 02-23-2012, 11:25 PM
By wytstang in forum Off-Topic
Last Post: 05-06-2009, 10:35 PM
By hydro556 in forum Auto Detailing 101
Last Post: 08-01-2007, 06:33 PM
