Results 1 to 4 of 4
    Sep 2010
    74
    Rubber Molding - Rear Window
    I am about to start work on a Scion tC. The rubber around the rear window is in poor shape - it is stained and generally rough. What is the best approach to use?
    Re: Rubber Molding - Rear Window
    Quote Originally Posted by phantom View Post
    What is it stained with?
    Dried out from exposure to sun?
    Stained from the guy before you getting polish and wax residue all over it?
    Pictures?
    Sep 2010
    74
    Exposure to the sun and not being cleaned very often.
    Super Member ShaunD's Avatar
    Nov 2010
    Va Bch, Va
    1,255
    Something like Black Wow Pre-Clean would work great, then use then treat with Black Wow or a rubber protectant. WGETS and OPT Opti-Bond are my two fav ext. trim protectants.
    Also, for cleaning rubber, I found a rubber cleaner for RV roofs. It can be diluted and is safe on paint, or can be used straight with no really concerns. I found it at Walmart in the RV section, next to the automotive section.
    One thing I have seen done is using a polish that has minimal oils in it to actually polish the rubber trim. If the rubber is very brittle you will probably have to clean it after polishing to remove any sign of polishing oils.
    Hope this helps.
    Shaun Shines Automotive Detailing, VIRGINIA BEACH, VA. http://www.facebook.com/ShaunShinesDetailing
  1. Cleaning window rubber residue off of window glass
    By nakranij in forum Auto Detailing 101
    Last Post: 04-19-2021, 07:46 PM
  2. help with window molding
    By sdm1001 in forum Ask your detailing questions!
    Last Post: 08-29-2019, 04:42 AM
  3. Window Molding Fix Options?
    Last Post: 04-02-2016, 01:06 AM
  4. Overspray from window trim/molding
    By detailnerds in forum Ask your detailing questions!
    Last Post: 12-30-2014, 09:44 AM
  5. 2011 Expedition exterior rubber window molding
    By slowride66 in forum Ask your detailing questions!
    Last Post: 06-06-2014, 04:51 AM
