Ultimate Polish and M205 Problems
Hey fellas,
Was just trying to work in UP and it was flash drying on me after just three passes. I was following up Ultimate compound. I switched over to M205 and again the same thing only after 4-5 passes. The vehicle recieving the treatment is a red C5 Vette. I had to IPA the dried on polish. Any ideas why my stuff was flash drying on me? Also both products less than 2 years old.
Thanks
Re: Ultimate Polish and M205 Problems
you might be using too much product. work also on a small area at a time.
Originally Posted by smack
Hey fellas,
Thanks
Could be the detailing area/vehicle's:
-panels'/area's temp
-humidity [relative and absolute(dew point)]
-ambient temp
-wind speed...including fans (if applicable)
Probably a few more environmental causes that's not listed...
Hope you get everything tuned in!
Bob,
Car was in garage the during the process in 65 degrees Las vegas weather. No fans so no wind. I would imagine low humidity.
Ginnova,
I might have been using to much product now that I think about it. If I over apply polish would that cause it to flash dry on me?
What kind of speed and pressure was being used?
Bob,
That can pretty much rule out my previous thoughts, then.
I suppose it gets back to the products/processes...Their ages, exposure to different storage temp ranges; machine/arm speeds, pressure; pads...priming, type, condition....
Just me guessing....Probably not much help, Sorry...
Wish I was there...Might be able to take a more educated stab at your dilemma.
EDIT: Low humidity, coupled with medium temps is not always a good thing....Less moisture in the 'air'...if you get my drift.
I was using both products on Megs foam finishing pads. Of course one pad per product. Both were being used on the 3 and 4 speed range. I think I over lubricated the pad and finish. I got out of control because at first it was going fine then I kept adding more and more product thinking that I would get a longer buffing cycle but I saw that it was getting worse. In which case I stopped what I was doing.
Glad you found the culprit, and the solution!!
Happened at least once to many of us.
Flex 3401 & PE14
how could adding more product cause it to dry faster? if anything, wouldn't it cause longer buffing time and more lubricating agents? how is it dry buffing with MORE product?
By Bobbykart in forum Auto Detailing 101
Last Post: 05-03-2018, 10:48 PM
By RolloMay in forum Ask your detailing questions!
Last Post: 07-21-2016, 07:52 AM
By SArao in forum Ask your detailing questions!
Last Post: 10-01-2014, 11:25 PM
By jankerson in forum Show N' Shine
Last Post: 10-24-2013, 08:27 AM
By wlpncp in forum Auto Detailing 101
Last Post: 03-02-2013, 12:59 AM
26 | 27 | 28 | 29 | 30 | 31 |
