Sealant Advice?
Hey guys.. I've been noticing an issue with the durability of my Wolfgang paint sealant.
If drive the car through a rain storm or two, let the dirt/grime sit on the car for that week, it will basically strip my Wolfgang sealant off when I wash it. I have to wash the rear of the car 3 times to get it clean.. and it barely beads at all afterward. The rear of the car is beginning to show a little marring since it isn't well protected! All of this after the sealant was applied two weeks and one wash before. It's fresh sealant!
I usually apply the wolfgang once every 2 months & let it sit overnight for curing. The areas that do not get soiled from rainstorms are amazing. Incredible gloss, beading, sheeting, and smoothness on the hood & roof that lasts.
I use this for washing, which seems to be very gentle:
I also have another wash which is a little more aggressive.. made by a local detailing company, but it takes the smoothness away from the entire car. I really do love Wolfgang sealant, but it just seems weak.
Do you all have any suggestions for the most durable sealant available? I want to keep that incredible slick finish & protection for the entire car.
Thanks
Re: Sealant Advice?
So far I have had great luck with Wolfgang sealant and my new favorite is Blackfire Wet Diamond. You can always add Collinite 845 for more protection.
I am sure there are stronger sealants/combos out there and I am sure people with harsher weather will chime in. Not much rain here in SD.
Re: Sealant Advice?
Thanks! Maybe that's what I'm lacking.. protection for the protection. I don't wax it after I put the sealant on. Maybe I'll pick up some 845 and throw it on top and see if that helps.
Re: Sealant Advice?
The car wash you're using works well and if used according to Meguiar's directions should provide you with the results you're looking for without stripping sealants and waxes.
Wolfgang Deep Gloss Sealant is a nice product however from what I've seen lacks long term durability.
Sealants
Layering sealants also seems to improve things an adding a wax like Collinite 845 adds an extra barrier of protection as well.
Re: Sealant Advice?
What kind of prep are you doing before applying the WDPS?
Re: Sealant Advice?
This...and are you allowing proper Dry/Cure time before doing anything else to it.
Re: Sealant Advice?
The high solvent content of 845iw will tear through the Wolfgang. Don't waste your time. 2 coats of 845a will more then meet your needs.
Re: Sealant Advice?
It's all about the prep. Clay, polish, IPA wipe to prepare the surface, then apply LSP(s). A well-polished surface will provide much better water beading/sheeting. If the paint surface is full of embedded contaminates, it totally ruins the effects your looking to get out of your sealant, try the plastic bag trick on the troublesome section.
Why do you have to wash the rear section three times to get it clean? That seems odd, is it a repaint?
When you leave the sealant on to cure overnight, is the car inside away from any dew/condensation?
Re: Sealant Advice?
I believe this to be true too. I see many people say that they put 845 over another product, and I think the best that one can hope for is a mix of the 2 after curing.
The 845 is so high in solvent, that I don't think any traditional sealant could be undisturbed when appying 845 iw.
Re: Sealant Advice?
Also, if you can find it, try Autoglym HD Wax. Great long lasting protection and beading.
By ScottStoef in forum Auto Detailing 101
Last Post: 10-08-2018, 07:09 AM
By Mongoose71 in forum Ask your detailing questions!
Last Post: 06-03-2013, 09:06 AM
By ml13 in forum Auto Detailing 101
Last Post: 12-06-2009, 10:14 AM
By Turd Ferguson in forum Auto Detailing 101
Last Post: 11-07-2009, 12:15 AM
By Ernie Ball in forum Auto Detailing 101
Last Post: 06-28-2006, 07:39 PM
