Re: Paint Chipped away!!! :(
Yeah, that's too many pictures. Most people don't do the clear on top for the reasons you stated.
You probably aren't going to get that so you can't see it, but if you're careful you should be able to make it less noticeable. Be aware that you can remove touch-up paint with solvent, like laquer thinner, so if mess up you can wipe it out and start over. You can also do your own Langka thing with some cloth (or I've even used a paper towel) and a flat something, and the laquer thinner.
You might want to use some masking tape adjacent to the chips while you are filling them in.
Oh, I forgot to mention, don't listen to me because I hate doing touch ups because I suck at it.
I just bought an airbrush and some Dupont auto paint. I plan to post some pics when I am done, assuming it turns out well. We will see...
ty, Setec for your laquer thinner / Langka thingy tip (actually, I never seen / heard of neither.. but I just google it and found that it might get the paint flat... and perhaps do more light wet sanding then compound and polish)
Harsh, please let me know how it goes and the procedure. I might spend even go that way if it looks good.
Another Question, will laquer thinner ruin the exiting factory clear coat / paint?
Use the Dr. Colorchip system. It's the best chip/scratch repair sytem I've ever used.
I am told Dupont 3812 reducer will not harm clear coat, but I belileve it will clean up base color so you just have to be sure you are using it only on a cleared surface, unless you are trying to cleanup some base color that did not go so well. Also, I was told to use the 3812 to prep clean the area before I start spraying color with the air brush. I have a little practicing to do but I will post a full write up once I am done.
Last Post: 07-09-2014, 06:43 AM
By Komedian in forum Ask your detailing questions!
Last Post: 06-14-2014, 05:16 PM
By Ncs0816 in forum Auto Detailing 101
Last Post: 05-24-2013, 01:37 AM
By SATracker in forum Auto Detailing 101
Last Post: 12-17-2008, 01:21 PM
By id-type-s in forum Auto Detailing 101
Last Post: 03-01-2007, 01:58 PM
