Big mistake
I had rock chip on my hood so i tried to wet sand it and polish to remove it and i ended up got gray spot on it.
Can anybody tell me what i did wrong?
Re: Big mistake
Sounds like you removed to much clear coat and have now exposed the basecoat which isn't normally glossy but matte.
Did the spot start out small and the more you work on it grow?
Re: Big mistake
What color is your car?
The factory paint on newer cars is scary thin and leave little room for error. Many manufactures control the thickness of each layer through positive and negative charging of the panel and paint particles. It's very common to see paint film thicknesses of 0.001" or slightly less...
You may have sanded through the clear coat and exposed the color coat. In this case you can take it to a paint shop and what the hood re-cleared.
Many manufactures use gray primer or base coats prior to the color coat. These coating bond well the the metal surface and provide a perfect surface for the color coat to adhere to. If by some chance you exposed the primer or base coat then the hood will have to be repainted to match the rest of your car..
Re: Big mistake
It was small and as i worked on now it is almost pea size
Re: Big mistake
My car color is white nissan nv1500 i guess i have to repaint it
Thats the best option
Re: Big mistake
if its a pea sized spot call around and see if any body can do a spot repair on that panel, some times they can just mask off the area spray some paint/clear on it and feather it so you cant even tell it was ever there, call up a dealership and ask them if they use a onsite spot repair service and see if they can give you a number, another option is call a air brush artist or custom paint company and just basically tell them you dont want to pay for a repainted panel all over a pea sized spot, i would try those options before getting it repainted... good luck to ya
By chops1sc in forum Auto Detailing 101
Last Post: 12-03-2020, 07:19 AM
By Jmbrown415 in forum Auto Detailing 101
Last Post: 12-10-2016, 10:24 AM
By DogRescuer in forum Auto Detailing 101
Last Post: 08-13-2015, 04:53 PM
By John_Jethro in forum Wet-Sanding, Cutting & Buffing
Last Post: 04-23-2015, 06:56 AM
By theeeeric in forum Ask your detailing questions!
Last Post: 08-20-2012, 12:13 PM
