Re: Your advice for a super soft black Honda paint
That last pick has a patch of clearcoat failure.... A good paint job may be a costly choice... I hate Honda paint.
I would still recommend a new paint-job, though..
I have soft Toyota black paint. The only thing I could use to finish was 106FA or 85RD on a gray pad. Everything else left marring(power finish, 205 and etc).
The marks look like crows feet.
Same here I would use PO85RD to finish it off with. PowerGloss shouldn't be around Honda paint in my opinion. After my black '07 SI got back from a "body shop" I used 105, 205 and then PO85RD. I might of gotten away with using PO85RD after 105, but I didn't know at the time.
85RD on a black pad is what you'll need to use to finish.
"If I were stranded on a desert island and could only have one book, record and person...I'd probably die of exposure."
Thanks a lot for your advice guys.
That is a huge improvement over what it was before. The spot in the photo is called checking and it is deep cracks in the paint that goes well into the primer so your best bet with that is to use some rubbing alcohol on a cotton ball and soak the polish/wax residue to soften it before flushing it out with with a concentrated stream of water from a garden hose. Repeat this process until the white residue is gone so it is not so noticeable.
If you don't have a clear LSP such as UPGP or Opti-Seal then place a piece of painter's tape over it until your wax/seal/wipe process is completed so you don't refill it with a product that will turn white again once cured. Anything with Carnauba will look nice while still uncured but once it sets up it will turn white again and stick out like a sore thumb.
The other posters gave the same advice I would've given regarding how to finish the polishing, however most folks in the buyer's market would likely think in looks perfect as is.
I think you did great with what you had to work with...... and 99.492% of people wont see the imperfections that you see, very less know what they are.
Bates Detailing
I have had two Hondas and 85rd and 3m finesse-it II on a LC grey pad took care of any swirls in the paint. It was so easy to get holograms in that soft paint.
By Cool70cuda in forum Auto Detailing 101
Last Post: 09-09-2017, 04:19 PM
By lane5515 in forum Auto Detailing 101
Last Post: 09-02-2016, 06:23 PM
By spinz in forum Auto Detailing 101
Last Post: 01-03-2014, 07:11 AM
By BlackHawk in forum Auto Detailing 101
Last Post: 04-14-2013, 02:11 PM
Last Post: 04-14-2013, 01:44 PM
