Re: wetsanding with ONR?
anything that wont damage the paint...ive seen people use wax and grease remover as a lubricant
wax and grease remover? that has no lubricity, how would that work?
Hi !
ONR and Auto Magic Body Shine are the 2 products I use for wet sanding. I prefer ONR.
Metro Detroit's Leader in Vehicle Preservation & Perfect Paint Finishes
same here, i just wet sanded a headlight to test stuff out and the paper just glides so smoothly. i guess i will have to purchase a gallon of ONR. i bought the 8 oz since i had never tried it and so far, im loving this stuff!
Hi !
I have only west sanded a few times. every time has been with ONR
I wet sand with ONR all the time. I think it works much better. I've even used spray wax. I just soak my sandpaper in warm water to soften it up, spray some ONR and go at it. IMO, it's perfectly fine.
Interesting use of ONR. I've always just used plain water. Maybe ONR acts like a water wetter also.
If I understand you correctly, if it's getting stuck, I'd use more water (from a spray bottle). It's similar to compounding (only extreme). There is a lot of removed material "gunk" that is clogging up the sanding sheet that you want out of the way so the abrasives can do their work. I also wouldn't want any extra heat in there.
I have limited experience with wet sanding but the few times I've done it I've used ONR as my lube.
I use water with a few drops of Meguiar's #00 Hi-Tech Wash... guess I'm just old-school like that
By Mike Phillips in forum PICTURES: Wednesday Night Detailing Classes
Last Post: 07-12-2019, 03:11 PM
By Theraven in forum Boat & Marine Craft Detailing
Last Post: 03-18-2013, 01:00 AM
By bova80 in forum Auto Detailing 101
Last Post: 11-07-2010, 12:30 AM
By -Javier- in forum Auto Detailing 101
Last Post: 05-03-2008, 01:46 PM
By iMt in forum Show N' Shine
Last Post: 11-23-2007, 09:10 AM
