Used Car Dealer
I am a used car dealer and have traditionally paid for detailing of my vehicles or just washed cleaned and sold. We are moving to a new indoor facility that is further away from my trusted detailer. So I am looking at doing some of the work myself. We deal in mostly 2007 or newer Acura and Honda vehicles. We are a 100% indoor dealership as we generally have 15 or so high quality vehicles at any given time. I have little detailing experience other than tradition cleaning not detailing. Considering coming to your courses.
I am looking for two solutions
- A fast way to restore paint finishes on Acura MDX's, Odyssey Touring etc.....
- A non body shop alternative to repair deeper scratches that require touch ups etc
What polisher, pads, products, would you recommend for approx 4 or so cars a week? Do you teach or have a paint touch up solution?
Re: Used Car Dealer
It sounds like the Megs new mf system and some Dr. Colorchip.
Re: Used Car Dealer
Start here for recommendations/how to's:
Ask the Expert featuring Mike Phillips - Auto Geek Online Auto Detailing Forum
For non-body-shop alternatives for deep scratches, check out Dr. Colorchip in the Autogeek Store.
Re: Used Car Dealer
I have not personally used this product but from what you said it sounds like what you want.
Meguiars DA Microfiber Correction System, paint polishing system, car polish, car detailing system, compounding system, remove scratches
I have used this and love it! Just takes a little technique the first time and then its easy. For metallic paints results may not be quite as perfect.
Dr. ColorChip Paint Chip Repair, repair paint chips, touch-up paint, Doctor Color-Chip Paint Chip Repair
Re: Used Car Dealer
How refreshing to have a used car dealer come to our forum to seek advice. This is a first I do believe.
I would get a Griots 6" DA along with a 5" and 3" backing plate
I would order as many of the following pads as you can afford at this time.
Surbuf Pads
Orange Foam
Yellow foam
Black foam
1 gallon Meguiars 105
1 gallon Meguirs 205
On the Surbufs, I would only order the 6.5" pads and use your factory Griots backing plate for those
As for the scratches....Dr Colorchip is a good idea. I would also consider you check out the Mirka/Trizact sanding disks.
Do you have an air commpressor?
Oh yea, welcome from Memphis
Re: Used Car Dealer
Surbuf Pads
Orange Foam
Yellow foam
Black foam
Thanks for the advise I do have a compressor have you tried this new 2 step MEG solution it sounds the easiest if it truly works.
Re: Used Car Dealer
Anyone know of a good electric power washer that has soap dispenser etc?
Re: Used Car Dealer
They don't cut (remove defects) as well as the Surbufs. The choice is yours
Re: Used Car Dealer
I think what your looking for is a pressure washer with an after market foam gun attachment. No?
Re: Used Car Dealer
Yes you have any ideas portable or semi portable if possible
By Granite14 in forum Auto Detailing 101
Last Post: 01-29-2015, 08:34 PM
By AeroCleanse in forum How to make money detailing cars
Last Post: 08-16-2014, 09:44 PM
By swanicyouth in forum Off-Topic
Last Post: 08-23-2013, 09:04 AM
By c8n in forum Off-Topic
Last Post: 06-18-2013, 12:52 PM
By AeroCleanse in forum Off-Topic
Last Post: 06-01-2013, 07:35 AM
