Why the flat pads? Why the Griot Garage DA? Im in the market for an orbital too and thought the PC was the best (since everywhere I see it is referenced). Do I really need more power?
if there not flat all they do is start to rip and dont have the bite/cut to them . flat pads make the job go alot faster also
Do some research om the Flex3401, sorry Mark you knw I had to say something LOL....
Looked at and it's out of budget.....Griot's it is.
Originally Posted by merlin
The Meguiar's backing plate works best and is recommended by Meguiar's for using the Dual Action (DA) Microfiber (MF) correction system.
The Hook and loop on the Megs backing plate are shorter, creates less heat and has been tested and proven to work with the Megs DA MF system.
Once you get the DA (I have both PCxp and Griot's...I like them both...the Griots is a good choice) you will need polishing product.
To get you started I personally would recommend:
For the Foam Pads Megs M105 and M205.
NOTE: The 105/205 work best with the Kevin Brown Method.
or Meg Ultimate Compound and Megs Ultimate Polish
NOTE: The Ultimate products may be easier to start with.
Can I use the Lake Country Pads you referenced earlier or do I need to use Meguiars?
I'm sorry to all, this is VERY new topic to me and I'm trying to learn as much as possible and do it right so I don't screw it up!
The Meguiars backing plate tends to keep the the MF pads a bit cooler than the LC backing plate. When using foam pads, you can get away with either backing plate.
So when you say foam pads work with either plate that means the LC pads will work just fine with the Meguiars backing plate?
